Brake problem
Old Aug 31, 2006 | 09:36 PM
TestDriver's Avatar
TestDriver
Default Brake problem
However this post was made because as i was slowing down and hit the brakes my steering wheel started shakin real bad. Doesn't happen at lower speed i guess up to 70 u can say. I only also have an annoying squel type noise comming from my rear left wheel (This has been happening for a long TIME). What could it be?
Thanks for the help.
Old Aug 31, 2006 | 09:39 PM
Eyeguy77's Avatar
Eyeguy77
My guess would be rotors, mine started when coming down from higher speeds.
Old Aug 31, 2006 | 10:08 PM
jonecap's Avatar
jonecap
Warped rotors up front and crusty pads in the back.
Old Aug 31, 2006 | 10:26 PM
TestDriver's Avatar
TestDriver
I have only about 22k miles, however the stuff is all original.
Time for maybe some Brembo rotors and Hawk pads, what do yall think?
Old Aug 31, 2006 | 10:28 PM
TestDriver's Avatar
TestDriver
O and I forgot to mention the annoying sound from the back happens even when I don't press the brakes. So pretty much all teh time but as you start getting higher speeds you can't notice, but its still there!
Old Aug 31, 2006 | 10:30 PM
SSLT1KID's Avatar
SSLT1KID
yup, new rotors and pads all the way around will more than likely cure it. maybe even time for a C5 brake upgrade while you are changing brakes anyway.
Shawn
73-84 IMSA Widebody's Avatar
73-84 IMSA Widebody
Simple solution, don't do 120mph............
Old Aug 31, 2006 | 10:56 PM
rich653's Avatar
rich653
but if you are going to drive 130 mph I would definetly do the brake upgrade!
Old Aug 31, 2006 | 11:32 PM
TestDriver's Avatar
TestDriver
But my car came with the J55 brakes, zr-1 brakes. I really am not goin to change the rims yet so is it really worth changing out the whole system to a c5 one. Car is a 1995.
Also will new rotors and pads really stop the squealing noise that occurs without me even pressing the brakes?
Old Aug 31, 2006 | 11:45 PM
C4DC's Avatar
C4DC
St. Jude Donor '06
You just may need to rebed your pads (progressively heat them up a few times). I wouldn't upgrade the brakes, at most do a fluid flush, new pads, and rotors. If you start open tracking the car, then think about the upgraded components.
Old Sep 1, 2006 | 12:23 AM
Red_Vette_93's Avatar
Red_Vette_93
might want to check you rear spindles, being that old & not used might need replacing.
Old Sep 1, 2006 | 12:43 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
No and I don't know. I would start out by buying some brake cleaner and thoroughly cleaning the brake rotors.
Old Sep 1, 2006 | 12:46 AM
jakers's Avatar
jakers
St. Jude Donor '06
Default 285
Damn Sami,
I thought I saw a left lane white streak last time I was on 285! I would guess that was you. 130 jezz! I was rolling 85.... at the time!-
Old Sep 1, 2006 | 01:12 AM
creoleman's Avatar
creoleman
0-to-130 was exciting I'm sure, but you don't want 130-to-0 to be too exciting, if you know what I mean!
Old Sep 1, 2006 | 06:19 AM
MR NICE's Avatar
MR NICE
I say go for it your the one that pays your insurance premiums.I say go for 160
Old Sep 1, 2006 | 08:06 AM
vetteblack's Avatar
vetteblack
I say before you 'go for it', you should take a better look at your brakes and suspension for the squeeks and vibration your feeling. If you dont care about yourself, maybe you should think about other people on the road. You should also realize anyone can pull this tread up and read how your car is shaking at high speeds, and you still drive in this dangerious maner. Then they will sue the crap out of you, or your serviving family.
Old Sep 1, 2006 | 08:10 AM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Do it several times a weekend with mine at the strip. There should be no vibrations, sometimes I skid the front tires crossing the line to slow down (trying not to break out), and this is with all stock brake components. The rotors and pads have been changed. Last year my rotors had large cracks form in them! Still no vibrations.......
Might want to check everything out real good. And not to be a smart-azz, but don't do these speeds on the street - my family is out there. Go to a track and let her eat!
To Brake problem
Old Sep 1, 2006 | 08:31 AM
vetteblack's Avatar
vetteblack
OK, but if something happen to him going fast in that car, I don't think it would be that much of the stretch in court to pull up his post and put 2 and 2 together.
Old Sep 1, 2006 | 09:19 AM
GIJoe's Avatar
GIJoe
St. Jude Donor '08-'09
the squeeling noise could be a worn pad, you might want to check them out. jut pop a rim off and see how wore out the pad is. Even with low miles, you can wear pads out quick with aggressive driving.
I have EBC Sport dimpled/slotted rotors up front and oem replacement Brembo's in the back, with hawk carbon pads all around. Night and day difference when I replaced the rotors and pads. Smooth braking. Stops on a dime.
Old Sep 1, 2006 | 11:39 AM
Steel Blue 91's Avatar
Steel Blue 91
Not to rain on anyones good time, but there is a thread in OT about a guy who was doing ~154 MPH in this:
And it ended up like this:
Driver an passenger could not get out of the car and did not survive the fire.
Please save it for the track.
My rusty $0.02
