Help me adjust my timing....
Old Aug 31, 2006 | 10:32 PM
drewber's Avatar
drewber
Default Help me adjust my timing....
Ok, heres the deal. State emission inspections looks like this
HCs failed, No's extremly low. So I should be able to advance the timing a bit, drop the hc's and raise the no's..
I know where the bolt is with the prong that holds the distributor in place.
I know if i advance the timing the the RPM's will increase, and if i turn it the wrong way and retard the timing the RPM's will drop.
So I broke out my handy wrench, lossened the bolt, and well, the distribtor moved, seemed I had a tight spark plug wire. I dont know what way it moved. So I am looking at trying to set it back to base timing. Do i need to unplug the computer? I am afraid of trying to set the timing while the computer is making adjustments to fix my modification. I have a timing light, but ive never used one to time a car in the past. what do you all recommend?
Old Aug 31, 2006 | 11:21 PM
bogus's Avatar
bogus
how do you time a car without a timing light?
you have to disconnect the wire, not doing so will cause more problems than it's worth. The wire will be down around the brake booster.
Hook the timing light up to the battery, and the big clamp thingy (inductive pickup) to the #1 plug wire. Point the light at the crank pulley/timing marks and go to town.
Old Aug 31, 2006 | 11:24 PM
drewber's Avatar
drewber
Well its late now, so I will look for the wire in the morning. Wish me luck.
Old Aug 31, 2006 | 11:28 PM
bogus's Avatar
bogus
Old Sep 1, 2006 | 01:59 AM
Demonic85's Avatar
Demonic85
Like Bogus said, you need a timing light. You can pick one up at just about any auto parts store for cheap. All you need is the Inductive Timing one. Sounds like you rotated the timing a few degrees, no biggie. As long as you didnt pull the distributor out.
Disconnect the EST wire, its a round plug coming out of the wiring harness near the brake booster. Follow the directions to set the timing. A bit of advice though, the inductive pickup (the clamp) isnt supposed to clamp down onto the wire, it goes through the hole in it. Sorry, the timing light I got had confusing directions.
Old Sep 1, 2006 | 02:06 AM
cv67's Avatar
cv67
St. Jude Donor '05
The EST wire is brown I believe....Time it at 6 degrees, pretty sure the smog tech will double check that. Once timing is set reconnect your wire.
Old Sep 1, 2006 | 06:53 AM
Sam Lam's Avatar
Sam Lam
Your thread does not state what year of car you have and your profile is not completed. As stated,earlier, you must OPEN the EST connector and time the car with this connector opened or apart. Make sure the timing indicator on the front of the engine block is clean where you can see the reference numbers. Hook up the light to the battery and the inductance lead must go to #1 cylinder spark plug wire. Start the engine and shoot the light at the timing indicator. The timing light will allow you will see a line on the vibration damper and this line indicates TDC or top dead center of #1 cylinder. Move the distributor cap to where the vib damper line aligns with 6 degrees on the timing indicator. Tighten the distributor hold down bolt and rechech the timing it to verify it is still set at 6 degrees. Tighting the bolt will sometimes change the timing. Shut off the engine and reconnect the EST connector. Running the engine with the EST connector open will set a fault code in the car computer. Remove the negative battery terminal from the battery for about 30 seconds. This removes the fault code in the computer. Hope this is helpful.
Old Sep 1, 2006 | 11:20 AM
drewber's Avatar
drewber
ooops, profile updated.
1984 C4, automatic
Stock 350 V8 5.7L pretty much in rough shape, I wanted a project car to learn on. Didnt think it would be this expensive.
Old Sep 1, 2006 | 11:42 AM
CFI-EFI's Avatar
CFI-EFI
RACE ON!!!
To Help me adjust my timing....
