Questions about Fuel Injectors.
Old Aug 31, 2006 | 11:45 PM
Cold_B's Avatar
Cold_B
Default Questions about Fuel Injectors.
I am replacing the stock injectors with 30lb injectors at the suggestion of my engine builder, and I have a few questions.
Is there any difference in brand in injectors?
Is flow matching very important? What purpose does it serve?
Can the stock fuel pump supply 30lb injectors?
Thanks!
Old Sep 1, 2006 | 12:00 AM
bogus's Avatar
bogus
matching is a tuning trick. It makes sure that all 8 injectors are the same. This makes computer tuning that much easier.
What is happening to your engine that you need 30# injectors?
I would look at the FMS injectors (28# or so). The stock pump should supply it, but I would want to get a better pump if you have that much engine.
Old Sep 1, 2006 | 12:37 AM
Mo_Bandy's Avatar
Mo_Bandy
If you are not modifying the engine, I would stay with like 28's or so...
mo
Old Sep 1, 2006 | 01:13 AM
vader86's Avatar
vader86
Talk to your chip tuner before you buy the injectors, and dont buy Accels.
Old Sep 1, 2006 | 08:55 AM
Aardwolf's Avatar
Aardwolf
Old Sep 1, 2006 | 03:26 PM
Cold_B's Avatar
Cold_B
I am having a 396 520fwhp motor built, and the engine builder recommends 30lb injectors.
Old Sep 2, 2006 | 07:36 AM
RRT vette's Avatar
RRT vette
Originally Posted by CALI C4er
and don't buy from fiveomotorsports. They sell used injectors that they claim are new. They are under investigation for mail fraud.
Is not the first time I've heard that.
Old Sep 2, 2006 | 12:46 PM
edcmat-l1's Avatar
edcmat-l1
To Questions about Fuel Injectors.
