'85 Running Rich (VERY)
Old Sep 3, 2006 | 12:19 AM
H P Bushrod's Avatar
H P Bushrod
Moderator Emeritus
St. Jude 15 Year Donor
CI 5 thru 12 Veteran
St. Jude Donor '09 thru '23
Default '85 Running Rich (VERY)
My engine is mildly modded (Ported heads, LS-1 cam, longtube headers, chip burned for the mods). I thought the initial reason it was running rich is that I found a blown header gasket. I replaced both header gaskets and it still runs rich. Any ideas guys? Any info would be appreciated.
Old Sep 3, 2006 | 07:19 AM
RRT vette's Avatar
RRT vette
Have any codes shown up? Have you changed any thing lately that would have had to do with A/F ratio?
Old Sep 3, 2006 | 07:29 AM
edcmat-l1's Avatar
edcmat-l1
Lots of ideas, just not enuff info!
Old Sep 3, 2006 | 09:03 AM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
I had this happen once when I had been working on the engine, I had forgot to plug the connector back in on the maf. Check this connection and even if it's plugged in, give it a shot of contact cleaner and plug it back in.
Old Sep 3, 2006 | 11:35 AM
redrose's Avatar
redrose
CTS...check with a v-o-m and compare to temp chart in FSM
Old Sep 3, 2006 | 11:54 AM
CFI-EFI's Avatar
CFI-EFI
It appears this problem is not new with the header gasket replacement.
I thought the initial reason it was running rich is that I found a blown header gasket. Any ideas guys? Any info would be appreciated.
Lots of things could make it run rich. systematically trouble shooting the possibilities will save you from guessing and throwing money at it. Possibilities include:
A vacuum leak.
A bad fuel pressure regulator.
Leaky injectors.
O2 sensor problems.
TPS problems.
MAF problems.
MAP problems.
ECM problems.
Wiring to almost ANY sensor or the ECM.
Get out your FSM and start following the trouble shooting charts.
RACE ON!!!
Old Sep 3, 2006 | 12:34 PM
H P Bushrod
Moderator Emeritus
A vacuum leak.
Leaky injectors.
O2 sensor problems.
TPS problems.
MAF problems.
MAP problems.
ECM problems.
RACE ON!!![/QUOTE]
Thanks for the input guys. I'll start checking things on my next day off. Greatly appreciated! Stay safe.
To '85 Running Rich (VERY)
