2 Bolt 400 block strong enough???
Old Sep 4, 2006 | 12:02 PM
Brett Richmond's Avatar
Brett Richmond
Default 2 Bolt 400 block strong enough???
I have been looking for a 400 block and finally found one, it is a 2 bolt block that I want for a 406, build will be very simple but I need to know if I need to convert it to a 4 bolt main for safety reasons or if it will survice as a 2 bolt block. I am looking for about 450 hp out this with the right engine parts.
Old Sep 4, 2006 | 12:10 PM
Pete K's Avatar
Pete K
I would not be concerned if it were me. 400's have solid 2 bolt main caps.
Old Sep 4, 2006 | 12:50 PM
redrose's Avatar
redrose
the early 400 blocks were 4-bolt mains...when the change was made to 2-bolt main caps, the block casting was also beefed up in the main web area...some contend that 2-bolt blocks are actually stronger than 4-bolts..''splayed'' 4-bolt cap conversions are the best of both and are not expensive...if you only play nice, the stock 2-bolt should be ok, but if you're really gonna ''use it'', add the 4-bolt caps
Old Sep 4, 2006 | 09:17 PM
DanZ51's Avatar
DanZ51
Well the splayed conversion quote was around $500-$600, which doesn't qualify as "inexpensive" in my (check) book. The good point is my 400 is a "509" high nickel block. That and I (want to) believe the later 2 bolt was an improvement on the earlier 4 bolt blocks
Old Sep 4, 2006 | 10:05 PM
NitrousSam's Avatar
NitrousSam
Default 400 Sbc
400 to 500 horsepower with a 2 bolt should be fine.
Old Sep 4, 2006 | 10:10 PM
Vette Crazzy's Avatar
Vette Crazzy
2 Bolts Actually Have More Webbing In The Mains Than A 4 Bolt. Just Use Arp Studs For The Main Caps.
Vc
To 2 Bolt 400 block strong enough???
