big hesitation when cold
Old Sep 4, 2006 | 03:11 PM
lawnjockey's Avatar
lawnjockey
Cruising
Default big hesitation when cold
engine fires right up when cold, but when the throttle is blipped, there is a bad hesitation. After it warms up it seems to go away. no codes
Old Sep 4, 2006 | 03:17 PM
RRT vette's Avatar
RRT vette
Year of vette wasn't posted nor is it in your profile, but I see from a different thread that you have an 1986 vette. If you haven't...I would start with cleaning the IAC and throttle body. Also check the voltage at the TPS. With no codes to go by...you will be looking for things that won't set codes and the IAC and TB are two of them. If this doesn't help try some Seafoam. Other will suggest also.
Old Sep 5, 2006 | 12:24 AM
lawnjockey's Avatar
lawnjockey
Cruising
sorry it is an 86L with a compu cam 2040, adj regulator, and ported heads, etc.
Old Sep 5, 2006 | 03:36 AM
James Paradiso's Avatar
James Paradiso
I'm having the same prob with my 86. Fully stock except for a adjustible FPR, K&N, 160 stat. Starts right up when cold but if I try to rev it a little then it will hesitate or choke itself. I usually let it idle for about 3 minutes and this goes away. I replaced my IAC and checked my TPI voltage. Still no luck....
Old Sep 5, 2006 | 04:12 PM
lawnjockey's Avatar
lawnjockey
Cruising
any more ideas
Old Sep 5, 2006 | 05:34 PM
teebee's Avatar
teebee
2021 C6 of the Year Winner - Unmodified
My 94 LT1 is the same way.
Old Sep 5, 2006 | 08:13 PM
lawnjockey's Avatar
lawnjockey
Cruising
i set the idle speed and tps voltage as the tech tips section said and I still have this problem
Old Sep 6, 2006 | 12:34 AM
black_89_vette's Avatar
black_89_vette
Maybe it has do to with open loop / closed loop operation on the chip. Have you ever had your chip programmed or tinkered with?
If it happens when it's cold but goes away after 3 minutes or so that's what it sounds like to me. I bet it also happens when warm, just on a restart right?
Old Sep 6, 2006 | 08:49 PM
lawnjockey's Avatar
lawnjockey
Cruising
after it is hot, it helps to give a little gas, but it does not have the hesitation. It is the stock chip
Old Sep 7, 2006 | 09:41 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Could your ECM be going bad? I know you said you're not getting any fault codes, but sometimes they can go **** up without throwing codes.
To big hesitation when cold
