Weight Reduction--C4 Doors
Old Sep 4, 2006 | 10:12 PM
NitrousSam's Avatar
NitrousSam
Default Weight Reduction--C4 Doors
Does anyone who if there is any weight within the C4 doors that can be removed without doing away with the glass and power windows? My Malibu doors had a beam inside the doors that saved 12 lbs per door when removed.
Thanks,
NitrousSam
Old Sep 4, 2006 | 10:27 PM
hookedup's Avatar
hookedup
Yes there is a beam in the door, but after I looked at what was required getting to it and then removing it I put the panel back on.
Good luck,
Dave
Old Sep 4, 2006 | 10:38 PM
redrose's Avatar
redrose
with lexan windows you would'nt need power...toss the power door locks and the jukebox speakers...now the whole wiring harness can go.
gotta give up something if you're gonna build a flyer.
Old Sep 4, 2006 | 10:42 PM
NitrousSam's Avatar
NitrousSam
Good luck,
Dave
Did it look like a steel beam?
Old Sep 4, 2006 | 10:43 PM
NitrousSam's Avatar
NitrousSam
Speakers will be coming out for sure. I won't be adding lexan side windows but I did buy a lexan rear window and boy is it light compared to the huge and heavy rear glass.
Old Sep 4, 2006 | 11:06 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Yes, but I'm not sure if the door would hold together without it. In 85, there was a corrugated steel beam fused to the door panel and welded to a plate on the lock side, and to some more steel where the hinges attach. GM got rid of most of this steel beam sometime before 1989.
Old Sep 4, 2006 | 11:12 PM
NitrousSam's Avatar
NitrousSam
I am wondering if there is a way for me to remove the face of the beam but not remove the entire beam. Maybe just the way it attached to the door itself. My doors are 1984 so I am guessing they may have the steel beams. Thanks for your comments
Old Sep 4, 2006 | 11:25 PM
CentralCoaster
It's a corrugated piece of sheet steel (folded back and forth like so... _n_n_n_n_ ), there is no face of the beam. You could probably cut it longways though with a nibbler and remove the center few ribs out of it. Might be worth 10+ lbs total.
Old Sep 4, 2006 | 11:27 PM
NitrousSam's Avatar
NitrousSam
It's corrugated, there is no face of the beam. You could probably cut it longways though with a nibbler and remove the center few ribs out of it. Might be worth 10+ lbs total.
Thanks again. 10 lbs would be worth it to me...I am guessing it is going to be a pain in the tail to get to though.
Old Sep 5, 2006 | 12:35 AM
Slalom4me's Avatar
Slalom4me
NitrousSam
I wonder whether the good folks at Vette2Vette could help out
by checking door weights. They may even have these written
down for different years to assist with with shipping.
Drop a dime.
Even if there is no difference, you may be better off to get
a spare pair of doors. You could section them, gut what you
judge unneccessary and then glue them back together without
remorse.
Old Sep 5, 2006 | 08:52 AM
NitrousSam's Avatar
NitrousSam
Originally Posted by Slalom4me
NitrousSam
Drop a dime.
remorse.
Thanks Slalom...that is a great idea. I will check into it this afternoon.
Old Sep 5, 2006 | 09:18 AM
Vetracr's Avatar
Vetracr
Just for reference you can totally gut the door to the exterior shell if you leave a few inches if he inner fiberglass lower panel. Think of it a door pocket. You can still use stock door latch mechanism.
Larry
Old Sep 5, 2006 | 10:24 AM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
Slightly off topic, but what did Chevy do after '89? I've never taken apart my C4 door panels, but I assume there's some sort of side protection beam in the later ones too. Was there a lighter design in the later cars? I'm very interested in what numbers (weight wise) the various door vintages come up at.
Old Sep 5, 2006 | 12:05 PM
Slalom4me's Avatar
Slalom4me
I made a quick attempt to check the Melrose site yesterday to
see whether they listed doors. Ran out of time ...
Melrose carries or carried several items for C4's. Doors might
might be on their list too and if the price is right then this saves
you some work.
Old Sep 5, 2006 | 08:14 PM
NitrousSam's Avatar
NitrousSam
you some work.
I bought my Lexan rear window and roof skin from Melrose...Nice Folks!
Old Sep 5, 2006 | 09:40 PM
CentralCoaster
Dunno. I've only seen the insides of a 84, 85 door and 89 door. I guess GM decided the crash protection in the 85 door was overkill. The 89 had a much smaller cross piece.
Old Nov 10, 2006 | 08:01 PM
C4forlife's Avatar
C4forlife
I can't remember the exact number but the bare bones door shell with no hinges weighed 25 or 30 lbs. To take a significant amount of weight out of there would mean just going straight to carbon fiber doors which I think Exotic Muscle still offers. Also, does melrose have a website?
Old Nov 11, 2006 | 12:38 AM
kopbet89c4's Avatar
kopbet89c4
I wonder if it would be possible to fab up some simple manual window rollers rather than this unreliable set of window motors and complex mechanisms...
Sometimes the pass. window would roll down, but not back up. I'd have to hit it a little for it to roll up.
Old Nov 11, 2006 | 08:23 AM
Mojave's Avatar
Mojave
Do they have a website?
To Weight Reduction--C4 Doors
