I replaced the main harness on my 90 vert and everything went smooth except for one thing, I can't seem to find the connector for the cruise control switch located on the brake pedal with the hose connected to it. Now I don't recall if I removed one from it since it was a while ago that I ripped the harness out and didn't make a notes of any connector locations. I did check the manual and it looks like it dosen't have an electrical connection. Any help would be great
I just want to know if the switch (release switch/valve) has a connector that comes from the main harness. I can't remember if I pulled one off. the switch has a vacume and electrical connection
I can tell you that replacing the main harness in an early C4 is NOT for the fient of heart.
Tell me about it, it took alot of patience, the job was too exspensive to have it done by a pro and by me doing the swap couldn't make it any worse then it was. so far I'm happy the way it's turning out.
