Help-buying an 89 vette
Old Sep 8, 2006 | 03:01 PM
richy rich's Avatar
richy rich
Default Help-buying an 89 vette
Looking at buying a very clean 89 coupe,auto.Besides appearence,what kinda stuff am I looking for?I have a 94 auto as well so I know the tranny could be a weak link.Anything else I should look at or ask about?These are Alum. heads,roller motors right?Thanks guys!!
Old Sep 8, 2006 | 03:18 PM
chucks88's Avatar
chucks88
Yeppers
How many miles on her
Old Sep 8, 2006 | 06:29 PM
GKK's Avatar
GKK
Look at the top rear of the block on the drivers side (near the distributor), for an intake manifold leak. The top sides of the block will be damp with oil. Also, look at the oil drain plug to see if there is an oil drip there because the intake manifold leak will usually travel down the bellhousing onto the oil pan.
Look at the top front and rear intake manifold torx bolts for coolant which indicates an intake gasket leak.
Make sure all the Digital dash gauge segments light up and are not dim or missing segments.
Old Sep 9, 2006 | 01:40 AM
pablocruise's Avatar
pablocruise
You may want to do a leak down test before the purchase.
Also you can do an exhaust gas analysis on the coolant to see if any exhaust gasses are present in it.
Our 89 L98's are known to blow the head gaskets.
Not a matter if, but when.
That's about the only BIG thing.
Other little minor issues only.
Good cars, receptive to mods(because it's a MAF car with the 165 ECM).
Old Sep 9, 2006 | 05:40 PM
richy rich's Avatar
richy rich
Its got 90000 miles on her-second owner-I will look for the manifold leaks.Great input fellows,I love this site!!
To Help-buying an 89 vette
