Clutch Fluid Stopper ??
I recently started to feel my clutch ceasing up or what I thought was going bad. After reading my posts in here, I checked my clutch fluid and noticed it was low. A real weird part to this is that the fluid resivoir has a rubber stopper/cup gasket on the top of it (black rubber). After getting a flash light and noticing that this was some kind of gasket or stopper I noticed that it was filled with brake fluid and possibley some rain water mixed in (seemed diluted) that may have gotten in through the tiny pin hole in the lid to the resivoir. I pulled out the rubber whatever and noticed that it was empty underneath. So I filled it to the full line. (Before filling I couldn't even get into gear and this happened within days, from working pretty good to screwed.) Anyways filled the fluid and then replaced the rubber cup. This thing is probably 2.5 inches deep or long. When doing this, the fluid started to be forced out of the top (the rubber deal being to long of big that it forces fluid out of the resivouir as i replace it back in and replace the lid. The stopper is deeper than the full and low line. I wrap a paper towel around the outside so that it doesn't come into contact with anything other than the resivoir.
So Im thinking this thing is the wrong one or that there doesn't even need to be a rubber what ever this is under the cap. It is a totally separate piece from the cap.
Does anyone have this in there car, do I need this or can I just take it out and use the cap only? There is a very small pin hole in the lid, so some rain could maybe make it in the resivoir and into the clutch fluid.
Bob W
Not near mine right now to check, but someone will chime in here to verify how deep down it goes.
Pinhole in the cap? Hmmmm....That doesn't sound right.
You will probably want to get some of the actual GM hydraulic fluid and flush the old stuff out. The GM stuff has some lubricating additives the brake fluid doesn't.
Just curious, have you disconnected your CAGS solenoid yet?
The rubber barrier is about one inch long and when you top off the reservoir, you cannot fill it!! You have to leave room for the barrier to be inserted. If you don't, then you'll have a big mess...as you've found out.
Richard Newton, in his book 101 Projects For Your Corvette, recommends this: "...fill the reservoir to 1/16" below the "low" mark so that when the "clean and dry" moisture barrier is re-inserted and the lid screwed on, the fluid level remains between the low and high mark."
I've found that this works nicely.
Hope this helps clear things up.
PS One more thing, if you "run out of fluid" then you have a leak in the system and should fix the problem.
Larry
code5coupe
