Oil pressure sensor is leaking
Old Sep 9, 2006 | 03:58 PM
XtremeVette's Avatar
XtremeVette
Original Founding Member!
Cruise-In 1, 3, 9. 10 & 11 Veteran
Default Oil pressure sensor is leaking
How do you go about fixing this? The leak appears to be where it is threading into the other oil pressure part. Can i just tighten the screw up?
Old Sep 9, 2006 | 05:03 PM
The Green Hornet's Avatar
The Green Hornet
From: Everyone needs something to believe in, I believe I'll have another beer. Wisconsin
I believe you will need to put a thread sealer on the threads, others may chime in tho
Old Sep 9, 2006 | 05:37 PM
87vette's Avatar
87vette
It needs to have thread sealer on it. I replaced mine as well when I did the intake manifold.
Old Sep 9, 2006 | 09:06 PM
Aardwolf's Avatar
Aardwolf
Sure, try tightening some.
Old Sep 10, 2006 | 09:17 AM
XtremeVette
Default tried tightening....no go
so I just changed it out.....
wow 5 minute job! Iam soooooo glad you guys pointed me to that one, I prolly never would have noticed that and would of went after the intake.
Thanks again everybody!!!! the place is great!
Jeff
To Oil pressure sensor is leaking
