Blown Fuses
Old Sep 11, 2006 | 09:10 PM
shenobi's Avatar
shenobi
Default Blown Fuses
I am new to corvettes and had to install a new combination switch in the steering column. I got it all back together and everything works except everytime I turn on the windshield wipers I blow the fuse for them. What is the best way to check for shorts that I may have created. Ihope I so not need to take the column apart again
Thanks for any help
Jody
Old Sep 12, 2006 | 09:38 AM
jfb's Avatar
jfb
Always post the year vette you are asking help for. I don't see any connection between the steering column wiring and the windshield wiper. The easiest thing to do is to unplug the windshield wiper and try another fuse. If it blows, then you have a pinched wire or a wire with abraded insulation touching ground and you need to inspect the wire supplying power to the windshield wiper motor.
