wheel question.. er verification
Old Sep 12, 2006 | 01:47 AM
bluedevil99's Avatar
bluedevil99
Default wheel question.. er verification
Im sure this has been asked before but Im just asking with my own personalized question!
These wheel spacers/adapters
http://cgi.ebay.com/ebaymotors/Wheel...mZ290024596421
work with this motegi wheel
http://www.tiretrends.com/wheel_cata...currencyCode--
to fit on a 95 corvette correct? Im a noob to spacing though so Im not sure about all the offset complications.. would an 17/18 inch stick out past the fender with the spacer?
Old Sep 12, 2006 | 09:14 AM
c4cruiser's Avatar
c4cruiser
The link you provided to the wheels only shows a 7 to 7.5" rim width. That's way too narrow for a Vette.
The offset listed is smaller than the OEM 56mm so those wheels by themselves will stick out too far as they are. An adapter would only make it worse.
Old Sep 12, 2006 | 01:41 PM
bluedevil99
so then what would be the minimum recommended width? 8.5? does one inch really make a lot of difference?
what about something like 18x8?
Old Sep 12, 2006 | 04:45 PM
z28cp's Avatar
z28cp
The other thing I noticed is, they don't list the Corvette bolt pattern as an option, either....
DaveZ
Old Sep 12, 2006 | 04:47 PM
bluedevil99
DaveZ
thats why I had the spacer, it allows for adaptation to any bolt pattern.
Old Sep 12, 2006 | 05:49 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
Don't know if rear wheels/tires will stick out, but to answer one question, yes, 1" does make a difference. Your car came with a minimum 8.5" front wheel (if Z51, it might've been 9.5" up front).
As to spacers, some may have good luck with them. However, many people that I know who've used them are not so lucky. If it was me, I wouldn't use them.
Find a wheel and bolt pattern that fits your car, is my recommendation, no matter how good the other wheels may look. Then find tires that do the same, fit the car and wheel. I believe you will be much more comfortable and happy with the results.
Old Sep 12, 2006 | 06:01 PM
bluedevil99
well basically the only other wheels that fit on vettes... are other year vette wheels...and that really isnt what Im going for lol
Whats wrong.. or unlucky, or what have you, with the spacers? what kind of problems do they cause?
Old Sep 12, 2006 | 06:24 PM
c4cruiser's Avatar
c4cruiser
DaveZ
The GM/Corvette bolt pattern is listed; its 5 on 4.75" (120.6mm) So the adapters would work on the Corvette hub but the studs on the adapter would still have to meet the wheel bolt pattern.
Notice in the pic of the adapter there is a recess for the lug that holds the adapter to the hub. If the wheels you are looking at do not have recesses in the wheel mounting flange and the studs sit out beyond the end of the adapter, that could mean that the wheel will not sit flush against the adapter. Some adapters come with acorn-style lugs and those are usually the ones that have problems with aftermarket wheels. Cutting down the stud on the car's hubs is not an option.
There are a number of wheel manufacturers that offer wheels for Corvette fitments. HRE, OZ, American Racing, CRAY and others. All expensive but they are very high quality wheels.
Wheel width does make a difference when you are using the proper size tires for the car. The use of narrower tires will not help handling and putting the power of the engine to the road. Even using factory sizes on narrow rims can cause the sidewall to be "bent" when mounted and that can generate a lot of heat and excessive sidewall flexing
The Corvette engineers went to great lengths to come up with the proper tire and wheel sizes. Going smaller can prove to be dangerous.
Old Sep 12, 2006 | 06:28 PM
bluedevil99
well no worries I have no intention of going smaller. But as far as the wheels made to fit corvettes are concerned, ive been having an incredibly difficult time finding them. They may be out there, they are just a pain in the a$$ to find.
Old Sep 13, 2006 | 07:07 PM
bluedevil99
ok then.. ive given up on the whole spacer idea, Ill take your guys' word that they are trouble.
Now ive set my sights on the black C6 MS
http://www.tirerack.com/servlet/Call...=&showRear=yes
I know the offset, bolt pattern, and other size issues are all good. They are a guaranteed fit. So NOW my question is, what size wheel do my stock tires fit on? stock are 17 front 18 rear right?
Basically what I would like is to upgrade to 18 front and back, but does that mean I am gonna need new tires? I had some width questions too, but thats not quite as important.. according to tire rack the back wheel has a 10.5 option, does that stick out from the fender? It looks like the front is a max of 9.5, and its 8.5 now right?
To wheel question.. er verification
