93 rewire battery?
Old Sep 12, 2006 | 11:06 AM
vettespd93's Avatar
vettespd93
Default 93 rewire battery?
Due to the vehicle being wrecked the battery will not stay in the vehicle it is sitting on the ground with the cables holding it up in the air. I am redoing some things on it and I was just going to put it in the back some place. I was wondering if i could wire it with 2 gauge wire and put it in the back of the car or something like that. Anyone know what i should do. it will be very hard to fix the tray area it used to be in so rather just do it this way
Old Sep 12, 2006 | 11:13 AM
RRT vette's Avatar
RRT vette
Is the battery tray broke or is the frame bent at that area?
Old Sep 12, 2006 | 11:14 AM
vettespd93's Avatar
vettespd93
tray is broken and in 100 little parts
Old Sep 12, 2006 | 11:17 AM
RRT vette's Avatar
RRT vette
If that is all that is keeping you from mounting the battery, you can get a used one from a salvage yard. I believe it is held on with 4 bolts. It's been a few years since I replaced one.
EDIT: actually there is a vette salvage yard about 15 miles from me. If you would like I could give them a call and get a price on one.
Old Sep 12, 2006 | 11:24 AM
Carpenter's Avatar
Carpenter
[QUOTE=RRT vette]If that is all that is keeping you from mounting the battery, you can get a used one from a salvage yard. I believe it is held on with 4 bolts.QUOTE]
I had a cracked tray, so I had one shipped to me from a wrecker. Cost $25.00 total.
Old Sep 12, 2006 | 11:45 AM
vettespd93's Avatar
vettespd93
ok great i would much rather do that if its possible give me a price that would be very helpfull. the body part near that is damaged i do have a replace ment but its off two so the battery is just laying on the ground and i cant move the car around do to this problem which sucks
Old Sep 12, 2006 | 11:52 AM
aminnich's Avatar
aminnich
You could also try vette2vette.com.
Old Sep 12, 2006 | 12:30 PM
RRT vette's Avatar
RRT vette
I just called Dino's Corvette Salvage and they have one but they want $50 not shipped. Seems a little high to me and I think you could find one cheaper at a different salvage yard or on Ebay.
Old Sep 12, 2006 | 02:24 PM
RRT vette's Avatar
RRT vette
Ebay
Saw this while I was passing through.
Old Sep 12, 2006 | 05:43 PM
ultraviolet70's Avatar
ultraviolet70
Try posting in the FS/WTB section someone might have one that's done a battery relocation.
Old Sep 12, 2006 | 07:53 PM
vettespd93's Avatar
vettespd93
ok great if i decide to do a relocation is that a pain in the you know what or something that is not to bad?
Old Sep 12, 2006 | 09:47 PM
c4cruiser's Avatar
c4cruiser
Relocating the batterry can be a PITA. There really isn't a lot of room in the existing storage box behind the passenger seat and rerouting the cable will not be easy. The positive cable has at least one wire that goes to the so-called "jumper terminal" that is behind the stock battery location and there are a number of fusible links there that feed various circuits.
You will have to increase the wire guage for the main positive cable and also for the wire to the jumper block. The negative cable can be attached to any large metal part of the car frame but make sure you have a good clean contact. Make sure the engine block has a good ground to the frame.
Don't leave the battery inside the passenger compartment unless you can seal the battery in a box and vent it to the outside. Gasses given off by the battery during charging can be toxic.
Guess I don't see why you cannot re-install a stock battery tray back on the frame. There are only 4 bolts and you will not have to mess with any re-wiring. Even if the lower fender gill panel is not installed, you can still drive the car.
Old Sep 12, 2006 | 11:02 PM
VenkmanP's Avatar
VenkmanP
It would be real dumb.
Re: $50 price for shelf - 40' of #2 wire is going to cost more than that.
Old Sep 13, 2006 | 01:51 PM
vettespd93's Avatar
vettespd93
ok thanks for all the great info. I looked at the old tray area today in the light it seems like I can just bolt one back in that place. It looks like there are two top bolts and two lower side bolts. the car was wrecked in the front and the battery was lose and when we pulled it off the tow truck when i bought it the battery fell against the tire. Not knowing that as we rolled it off the truck the battery turned causing it to keep turning and burst out the side panel and breaking the tray. Thanks
To 93 rewire battery?
