limp home mode
Old Sep 12, 2006 | 08:52 PM
wjmac40's Avatar
wjmac40
Default limp home mode
Car has gone into limp home mode again
Had issues with MAS in past however this seems different
Question is I put a timing light under this rough idle and it's miss firing to the point it fires now and then.
Is this the way limp home mode works or do I have another problem?
It's a 1989 and it is blowing black smoke and using fuel at an incredable rate.surging at any speed,and not holding an idle.The light is showing up before the timing plate and only firing now and then
Old Sep 12, 2006 | 10:11 PM
vader86's Avatar
vader86
What code is showing?
Old Sep 12, 2006 | 10:21 PM
wjmac40's Avatar
wjmac40
Thats the thing ,I'm getting no code at this point
Old Sep 13, 2006 | 09:45 AM
rick lambert's Avatar
rick lambert
I'd start with a fuel pressure test..could be you have some bad injectors. Next I'd pull the ICM and have Autozone check it....while it's out Ohm your pickup coil.
Old Sep 13, 2006 | 10:00 AM
jmrl98's Avatar
jmrl98
I would think if it's truly limp home mode, you'd have a code stored. Fuel or spark is a good place to start, as suggested by Rick.
Old Sep 13, 2006 | 05:39 PM
Snakecharmer383's Avatar
Snakecharmer383
I had some similar problems with my 89. I wasn't getting any codes either, finally when I unhooked the scan tool and rehooked it up I got a Code 43 (think it was 43) which is the EST (electronic spark timing) I replaced the module and all was fine. I would also check the knock senor.
Old Sep 14, 2006 | 12:15 AM
SSLT1KID's Avatar
SSLT1KID
did you try disconnecting the battery to see if it comes back? how do you know it is in limp home mode?
Shawn
To limp home mode
