Several years ago, I ran with no cats for 1 day.....the smell of raw fuel was way too much for me. And, I really didn't feel much of a power increase. That being said, you're better off going with a hi-flow metallic substrate cat.
Living in Florida.. I would never drive a car with cats... that and my first car came from the factory without them... Even with my long tube headers - x-pipe and Flowmasters I still think mine could be louder... and I'm not smelling the foul smells other people are talking about either.... even if I did -- I tend to like that smell having grown up around race cars 24/7.
I ditched my cats a LONG time ago. The precats both went a few weeks from each other and clogged the main cat. I then rammed out the main cat with a crowbar, so my exhaust is pretty much free flowing.
Also, I have never even once smelled the smell everyone tells me you will get from no cats (fuel or sulfer smell) and I have been running without them for 4-5 years now.
I do have to say, you pick up some nice breathability from loosing the main cat, or gutting it out. if you've never seen inside one, its just a honeycomb filter of chemical media (toxic, don't dispose of it in the ground) that I am not sure how the air even gets through effectively.
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Originally Posted by ALLT4
Aight, cats it is. Thanks for the input.
I think it behooves us to be responsible in our hobby so we can enjoy it for sometime to come. Plus I want my granddaughters to grow up with clean air. Modern factory and aftermarket cats are nothing like the ones GI Joe describes. Properly sized in a well designed system, they'll rob virtually no HP.
I am guessing this is why the cat on my Tibby was so small (almost an inch larger around thant the rest of the exhaust pipe) compared to the super huge one on my vette and beater prelude. Interesting to know!!!
The flow on the tiburon was soooo much better than the one on the Vette it seemed.
There are no pre-cats on the LTx cars, and even the factory installed main cats flow really well.
100%
GI Joe - you removed a very poorly designed exhaust on that L98. I hate that design.
However, adding a pair of bullet cats to the pipes, an x-pipe and some nice mufflers might actually get that engine running better.
I know what you are saying, but the issue, to me, is bigger than just being loud.
It's about being concerned about the air we breathe, and the future for our children.
I am concerned that the collective ground level polutants will get so out of hand, that the EPA will mandate sniff testing in every part of the country. When that happens, well... I wouldn't want to be in your shoes.
Modern technology rules! Wish I could afford a C5
so with no main cats or precats is it to loud and would you have some sound clips
I tend to agree with you. However -- the better aftermarket options rob your wallet. If the cats were as free as felines I may have even said what the heck and put on some new ones. (my initial reason for getting rid of them [before the catless headers] was that one was partially clogged and poisoned... when I removed them I found that both were already broken inside as well). Again, for a Floridian it is hard to justify the extra money especially when there are some minor benefits to having no cats.
Originally Posted by GIJoe
EEENNNteresting...
so the bullet style (I think that was what I was thinking of) came on cars from the mid 90's and later I am assuming?
If you buy any universal replacement cat these days, it'll be of the modern design and so not very restrictive for a given size. I've got some universal 3" cats from NAPA that cost me about $65 each. Internally they look identical to some $200 SLP cats I used to have. They probably flow at least as well as the 2 1/2" Random Technology cats that I use now.
I drive my car very little and as such acquired an "Exempt" sticker, meaning I can do what ever I want emissions wise.
I also live in PA and also drive less than 5k per year which exempts us from emissions testing. I'm not sure where Howard, PA is but in my area of PA even though I'm exempt from the sniffer I am subject to a visual test. So if your area is the same as mine you could hollow your cat, but you can't remove it.
From my experience (with my 95 LT1), hollowing the cats will lead to a backfire on decelleration. When I completely removed them with the header install I have absolutely no backfiring on decelleration now. I also have ZERO resonance after the header install and part of the problem may have been the gutted cats... this is with Flowmaster Super 40s too. Luckily I don't have any inspections, but if ALLT4 needs to pass such a visual I'd warn against just gutting the cats.
