383 stroker or not?
Old Sep 14, 2006 | 09:20 PM
all show and more go's Avatar
Default 383 stroker or not?
my friend swears his 1990 corvette is a 383 stroker but it doesent feel much faster. So is there a visual way to tell or maybe sound is different.
Old Sep 14, 2006 | 09:22 PM
Pete K's Avatar
Pete K
Nope. No way to look at the outside of the engine to see the difference.
Old Sep 14, 2006 | 09:37 PM
Brett Richmond's Avatar
Brett Richmond
Have you run them side by side?? It could be and not really be tuned right and is low on power. Did he buy the car that way and was told it was a 383?? Are there receipts for the motor work or dyno sheets???
Old Sep 14, 2006 | 10:06 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Pull the oil pan off and see if any clearancing has been done. I had to clearance the inside pan rail area of the block as well as the the bottom of the cylinders for rod clearance. I'm using a 3.80" stroke crank which is .050" longer than a 383 crank. I'm also using 6" H-beam rods. I'm relatively sure though that some clearancing is required for any 383.
Old Sep 14, 2006 | 10:09 PM
Rich & Lisa_84's Avatar
Rich & Lisa_84
From: I live at www.domesticlugnuts.com I sleep in PA
I only had one spot to clearence when I built mine and I only had to take about .010 off at that spot.
You may not be able to see it that easily.
Old Sep 14, 2006 | 10:19 PM
Corvette Kid
5.7" rods? If so, that may be the difference.
Old Sep 14, 2006 | 11:15 PM
pablocruise's Avatar
pablocruise
Sometimes machinists will stamp the stroke of a particular crank on the first counter-weight.
A possible clue might be an aftermarket oil pan or visible denting or notch work done on the pan.
Old Sep 15, 2006 | 08:48 PM
TRACKMAN2's Avatar
TRACKMAN2
if it blowes up its a 383
Old Sep 15, 2006 | 09:19 PM
Pete K's Avatar
Pete K
Amen
Old Sep 16, 2006 | 10:29 PM
STR8OUT's Avatar
STR8OUT
since its going to need a chip to run decently take the panel off of the ECM case and see if there is a sticker indicating what the motor is
my fastchip lists the CID, inj size, and cam on it
hth
Old Sep 19, 2006 | 08:44 AM
smokeshow's Avatar
smokeshow
Default its easy
most 383 are external balance so they use a balancer that has a cut out on it thats the way you can tell just look at the balancer if the out side o.d has a slot about 1/3 around the balancer then it is a 383 ,but then again if its a big money engine it might be internal balance ,but thats big money just for the crank and to balance it ,he probabley used a scat crank that what most people use for the one piece block and it would need the external balance harmonic balancer
To 383 stroker or not?
