heat riser
Old Sep 12, 2001 | 06:55 PM
jeffie86/96's Avatar
jeffie86/96
Default heat riser
Do I need heads with a heat riser provision on my 86? I would like to buy Bowtie heads but they do not have a heat riser passage. Thanks in advance. Jeffie :smash: :chevy
Old Sep 12, 2001 | 09:29 PM
lowflyer's Avatar
lowflyer
Cruise-In I Veteran
Default Re: heat riser (jeffie86/96)
No you do not need a heat riser provision for a TPI engine. The heat riser is for a choke assembly on carbs. Good luck.
Old Sep 12, 2001 | 10:27 PM
jeffie86/96
Default Re: heat riser (lowflyer)
I looked today and found there is porting under the manifold for heat crossover.
To heat riser
