New tranny cooler install
Old Sep 16, 2006 | 10:35 PM
NT Vettman's Avatar
NT Vettman
Default New tranny cooler install
Just installed a new tranny cooler. Instead of mounting it on the condenser as the instruction indicted. I made some brackets and mounted off the upper radiator support and the bottom cross piece. Worked out great. There is about 1” clearance between the condenser and the tranny cooler and there was plenty of room to rout the hoses to the steel lines. Looks like there will be plenty of air flow for each cooler. The 90 and up models have the radiator sloped back and it provided an easy way to mount it. I posted some pics of the install just in case someone was thinking of doing it and need some ideas.
Old Sep 16, 2006 | 10:59 PM
Lrod's Avatar
Lrod
Nice installation! How much of a diffrence in temperature does it make? I've been thinking of doing the same thing. I have a 96 with an oil cooler in about the same area, so I'll have to modify a bit.
Old Sep 16, 2006 | 11:09 PM
NT Vettman's Avatar
NT Vettman
I honstly don't know. I just put it in and have no temp guage. But I'm thinking about putting one in.
Old Sep 16, 2006 | 11:47 PM
Steel Breeze's Avatar
Steel Breeze
Looks good, at least you are a thinker. I would never hang a cooler of any kind off my radiator core...
Old Sep 17, 2006 | 06:43 AM
87 rag's Avatar
87 rag
That looks great. I would love to do the same thing but I have a fan in that spot.
My cooler is sitting on a shelf in my garage instead.
Old Sep 17, 2006 | 07:48 AM
Tom Piper's Avatar
Tom Piper
Nice.
What is the brand, and where did you get the cooler?
Tom Piper
Old Sep 17, 2006 | 11:31 AM
rickneworleansla's Avatar
rickneworleansla
Nice Install. I went with a B&M mounted on the AC condensor. Highest temp so far was about 189.
http://forums.corvetteforum.com/show....php?t=1471737
Old Sep 17, 2006 | 12:05 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
I made brackets and bolted mine in too. I don't remember the exact temperature reduction but it was significant. They're a worthwhile addition to any automatic equipped vehicle. Unlike an engine, you almost can't get an automatic too cool. A cooler trans = longer life.
Old Sep 17, 2006 | 05:07 PM
NT Vettman's Avatar
NT Vettman
The cooler is a Flex-a-lite model 4112. I picked it up at our local spped shop K-S auto. I had a gift certificate from Fathers Day I need to use and when I had my tranny rebuilt by Competition transmision he suggested getting one. So i figured it was time. I wasn't sure what size to get. This one says it's for standared duty with a GVW of 12,000, so I fiqured it ought to work. If any one out there knows how to size one I would like to know.
Old Sep 17, 2006 | 08:27 PM
Corvette Kid
I don't know if you plumbed it inline or as a stand-alone. But it appears to be of adequate capacity to work either way. Mine's probably a bit smaller but I put it inline after the radiator cooler. And I'm sure that temp reduction was (at least) a minimum of 30*.
Old Sep 17, 2006 | 09:25 PM
NT Vettman's Avatar
NT Vettman
I plumbed it inline. Every thing fit fairly well. Just had to bend the return line a little and it all went together
To New tranny cooler install
