1991 l98 vette engine trouble.
Old Sep 17, 2006 | 04:44 PM
jimmya's Avatar
jimmya
Default 1991 l98 vette engine trouble.
i recently bought a 1991 auto with the l98 tpi engine. when i got it, it was running bad, so when i got it home i checked the plug wires, made 1 new one, and fixed the problem. ran great for about 4 miles, when i decided to hammer down and blow the dust out of it. well, it ran great until i let off, then started missing again, worse than before. at this point it would barely idle. I replaced the plugs, replaced all the wires with new oem 8mm wires, replaced the cap and rotor. Seamed to be a little better, but when i test drove it, it felt like it was still running on 4 cylinders.Upon tearing into it, i noticed when you turn the key on, the fuel pump runs continuously, instead of for 2 secs like factory. then i found a jumper wire going from fuse box to fuel pump. apparently there is a relay problem or something. next i made a fuel press test gauge from some old a/c hoses. it has 39 at idle, and 45 at wot. next i put a scanner on it, all sensors seam to be working fine according to the readings from the scanner, and info from my tpi tuning book. FIRST, what do you guys think could be wrong, and SECOND, where is the fuel pump relay at? thanks.
Old Sep 17, 2006 | 04:58 PM
RRT vette's Avatar
RRT vette
Not sure if a 91 is the same, but on my 86 the fuel pump relay is located on the driverside of the windshield wiper motor on the firewall. Have you check fuel pressure after shutting down the engine for leaks? Have you ohmed the injectors hot and cold?
Old Sep 17, 2006 | 05:00 PM
CFI-EFI's Avatar
CFI-EFI
The fuel pump relay is on the firewall near the ww motor. Based on the fuel pressure you report, neither the relay nor the fuel pressure are causing the drivablity problems. But the wiring to the relay needs to be corrected. With your new car, you are going to need a FSM (Factory Service Manual) to learn exactly how each system works and for the trouble shooting charts you won't find in a generic repair manual.
RACE ON!!!
Old Sep 17, 2006 | 05:40 PM
jimmya's Avatar
jimmya
Default relay
ive seen pics of the relay where you are descibing in my haynes manual, but my car doesn't have one there. it does have a row of 5 relays hanging from under the pass. side dash near the fuse panel.could it be one of these? also it has 2 relays mounted on the drivers side of the radiator, i assumed they are for the fans? thanks for your input.
Old Sep 17, 2006 | 05:49 PM
CFI-EFI's Avatar
CFI-EFI
Before I say NO, who knows what a former owner did?
I would expect so. Test them. Now order your FSM so you can use that Haynes as a picture book and a wheel chock.
RACE ON!!!
Old Sep 17, 2006 | 05:53 PM
jimmya's Avatar
jimmya
Default manual
i hear ya, its not much help. i plan on ordering the good manual.thanks for the link.any idea on the 2 relays on the radiator?
Old Sep 17, 2006 | 07:16 PM
jimmya's Avatar
jimmya
Default info
im a nitrous/carb drag racer, but new to the fuel injected corvette. any info on engine/exhaust, etc. would be appreciated. im thinking on building a 377 with mini-ram and 58mm tb, true dual 3 " ex with no cats, and egr/smog crap deleted. any problems with this? (no legal issues, i live in arkansas!).
Old Sep 17, 2006 | 07:58 PM
Bruce Witherspoon's Avatar
Bruce Witherspoon
Sent you a PM.
Old Sep 17, 2006 | 10:06 PM
Sam Lam's Avatar
Sam Lam
jimmya: As RRTVette suggested, check the resistance of each fuel injector. The ohms should be between 16 and 17 ohms......and all eight injectors should be very close to the same reading both hot and cold. If you find injectors below 16, they are shorting out and this MAY be your problem. Very easy to check and rule it in.....or out!
Old Sep 21, 2006 | 07:25 AM
vette079's Avatar
vette079
I just ohmed my injectors on my ´91 after i read this, and found that 5 are over 17 ohm, 1 is at 13,9 and 2 are at 6,2 or so. No wonder mine goes like an audi. Are they easy to change and what is the best type to buy? Thanks for any reply...
Old Sep 21, 2006 | 07:28 AM
mseven's Avatar
mseven
That should not be "hanging" it mounts under the pass. side dash and is covered by the bottom dash pad/carpet, FP relay is the one in the middle in that row of 5. (actually I believe that "block" is labeled. IMS).
The other 2 by the rad. shroud are for the fans.
I would first get the electrical straightened out (as CFI originally suggested), ie. eliminate whatever jumper wires that should not be there and fix the problem.
Yes the FSM would help, I would also get the electrical volume.
Old Sep 21, 2006 | 07:33 AM
RRT vette's Avatar
RRT vette
The injector coil resistance is fried on the two mentioned. Either send all 8 off for service or replace with new. Make sure to get new o-rings befoe install. The job is not too difficult.
Old Sep 21, 2006 | 07:53 AM
Sam Lam's Avatar
Sam Lam
Please note the Multec injectors in your car are not serviceable and here is a note from Rich Jensen at Cruzin Performance on this issue:
Hi Bob,
The problem you currently have is that from 1989 through 1991 on the L98 engines GM installed Multec injectors. These injectors have one of the highest failure rates of any injector ever installed. It's not a matter of "if" they are going to fail, it's simply a matter of "when" they will fail. That is why some of your injectors look differently than the others. Some of them have obviously already failed and were replaced. Because of their design they cannot be repaired so the only solution is to replace them.
You can try to find some of the same injectors to use as replacements however they will likely eventually fail also so a better alternative is to replace them with an aftermarket set of replacement injectors or find some of the earlier Rochester injectors that were used from 1986 though 1988 on the L98's. These were a Bosch design injector and they don't have the problems that the Multecs do.
I don't sell any injectors so I can't help with supplying replacements but if you do find a set of the earlier design injectors I can service those and they have a very good track record of long life and serviceability. The part numbers you would be looking for are: 1986 = 5235211, 1987 and 1988 = 5235302. These are the part numbers that are on the injectors themselves. They are not the part numbers that would be listed in a GM parts catalog.
Sorry to be the bearer of bad news but that's just the way the Multec injectors are.
Hope this helps. Let me know if you need more info or have additional questions.
Rich Jensen
The injectors can be removed and reinstalled with 4-5 hours of your labor. The injecor removal time is reduced if you do not remove the runners from the intake manifold. The project requires some tools and in not a difficult job. If you want details on this, send me a note to samlam@charter.net
Old Sep 24, 2006 | 08:36 PM
jimmya's Avatar
jimmya
Default comp check
i had a feeling it was a mechanical problem, so i did a compression check. all 185-200psi, so i guess thats good news. moving on to injector check i guess. do you ohm them out from left wire to right wire unhooked, with the engine off, i presume?
Old Sep 24, 2006 | 09:30 PM
RRT vette's Avatar
RRT vette
Engine off. Disconnect the injector connector and you will see two terminals on the injector. Touch one with the red prong and the other with the black prong of the ohm meter, won't matter which terminal. This will give you a reading and should be around 16 ohm. Test all 8 cold engine and hot engine. The resistance shouldn't vary much if any if the injector coils are good. Compression looks good.
Old Sep 24, 2006 | 09:45 PM
jimmya's Avatar
jimmya
Default thanks.
thanks, this internet thing saves me a whole lot of time and money, trouble!
Old Sep 24, 2006 | 11:47 PM
ARatty385's Avatar
ARatty385
i just replaced mine with Accel 24lb/hr and we are back to running strong. The guys are right, it's not too much of a job to do. Devote a saturday and you're done.
To 1991 l98 vette engine trouble.
Old Oct 1, 2006 | 11:11 AM
jimmya's Avatar
jimmya
Default injectors
ok, i will test the injectors.
Old Oct 8, 2006 | 07:25 PM
jimmya's Avatar
jimmya
Default test.
ok. the injectors all test good. when i ohm out the left wire in each harness, the drivers side all have continuity and the pass side injector harnesses have none. any ideas other than the obvious bad wire?
Old Oct 8, 2006 | 08:21 PM
Sam Lam's Avatar
Sam Lam
It is good to hear that you do not have multec disease! I assume that you placed both leads of an ohm meter to the injector and measured the resistance across the injector terminals....right? The ohm reading should have been 16 to 17 ohms for all injectors. In reference to the leads going to the injectors: one lead goes directly to a 12 volt source (this lead is always hot with the ignition on) and the other lead goes to the ECM (to an injector driver or switch). The ECM switches one side or bank of injectors to ground and this fires four injectors (at the same time) for a very brief time period. Hope this makes sense to you.
