ac at idle
Old Sep 18, 2006 | 11:51 AM
8888vette's Avatar
8888vette
Default ac at idle
is ther a switch or vacuum line that mekes the car idle higher with the a/c on
thank you
Old Sep 18, 2006 | 12:24 PM
ODIVETTE's Avatar
ODIVETTE
When your AC kicks on, it puts additional load on your engine. You idle may be surging to keep the RPMs up? Does it race when the A/C is on and idling? Or does it just raise a little (it is supposed to do that)
Old Sep 18, 2006 | 04:16 PM
SunCr's Avatar
SunCr
There is a voltage signal from the dash controls to the ECM when a/c is requested and the ECM raises IAC counts to allow for the load of the compressor. Best to troubleshoot with a scanner as you observe compressor engagement as it will show you the request signal and the IAC counts. Otherwise, the signal comes in at ECM terminal B8. It will be 12 volts with Manual Air; about 6 volts with Electronic.
To ac at idle
