Re: Where is the lateral accelerometer in my C4?! (ToniH)
As a side note, it is my understanding that the later "Active Handling" packages use a "yaw" sensor that is more sophisticated and has more sophisticated electronics. So, I don't think the lateral accelerometer and the yaw sensor are the same thing.
Re: Where is the lateral accelerometer in my C4?! (Tom Piper)
on my '94 it was located behind the underside dash panel about where your right knee would be..
interestingly tho, i took mine out of the car and i don't get any codes..
the wire was broken to it when i bought the car and i pulled it out thinking it was part of an old alarm system or something.. later found a picture of it in my helm's manual.. never did put it back in tho.. no codes.. wonder if this is why my asr is so sensitive going around turns, leaving from a stop? ah well, with the 383 it's become routine to shut off asr as soon as the car starts anyhow!
