It should just be an issue of programing. Your old engine will go into the new car and you'll set up your old engine as a speed den. system using the electronics (i.e. harness, sensors and ECM) from the new car there by eliminating yopur MAF altogether. Get a chip burned fro your new ECM fro all the mods you've done. Esentially it's the same thing as modding a SD car like yours and getting it tuned.
