Compression Test, How are these Numbers?
Old Sep 20, 2006 | 10:14 PM
Jansenwins's Avatar
Jansenwins
Default Compression Test, How are these Numbers?
85 L98 with original shortblock. I swapped heads for some 64 cc edelbrocks. The shortblock has 121K on it. I did a compression test on each cylinder and got the following numbers:
1 - 204 2 - 202
3 - 214 4 - 211
5 - 201 6 - 204
7 - 212 8 - 210
The engine was warmed up to operating temp, and the throttle was held wide open. I gave each cylinder 5 rotations to achieve max compression.
How are these compression numbers?
Old Sep 20, 2006 | 10:32 PM
Pete K's Avatar
Pete K
They look just fine to me
Old Sep 20, 2006 | 10:33 PM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
They look fine
Old Sep 20, 2006 | 11:02 PM
Jansenwins's Avatar
Jansenwins
OK, Thanks! I was thinking that my rings must be worn out (considering the mileage), and considering making a shortblock freshen as my winter project. These numbers looked good to me but I am no expert. I'm thinking my rings are rock solid (knocking on wood).
Thanks again.
Old Sep 21, 2006 | 03:01 AM
JLeatherman's Avatar
JLeatherman
My 84 with pretty low mileage that sat around a lot before I got it is pulling 110-120 on 5 cylinders. I wish I had your numbers. It's rebuild time for me.
Old Sep 21, 2006 | 04:26 AM
comp's Avatar
comp
looks like rings and valve seats are OK
Old Sep 21, 2006 | 08:28 AM
IRAraid's Avatar
IRAraid
Default Compression Numbers
Jansenwins, the compression looks fine. How's your oil consumption? If it's good (low), valve guides/seals must be OK too.
Aside to JLeatherman: Drive it around for several tanks of gas. You might get a pleasant surprise. I've stored cars for a number of years and found that when first back on the road they smoked (blue oil fumes) for a few hundred miles then recovered very well (compression and oil consumption-wise). No smoke now either. (Didn't mean to hijack the thread.)
Old Sep 21, 2006 | 11:00 AM
Jansenwins's Avatar
Jansenwins
Heads are new so I figured this test would tell me how my piston rings are. The engine is not using oil....but, unfortunately it has a leak. Drips off the bottom of the bell housing, oil filter and gets on the drivers side collector. Been chasing it and can't find the start point of the leak.....
To Compression Test, How are these Numbers?
