coolant leak
Old Sep 21, 2006 | 12:29 PM
chevy bob's Avatar
chevy bob
Default coolant leak
I have a coolant leak on my 90 coupe, L-98.It appears to be coming from the drivers side and dripping down on the oil filter.It sure looks like a head gasket to me.Its wet right in the area in the back where the block and head come together.Is this a job to be attempted at home or leave to a pro?I've worked on older vettes,but this C-4 is a whole new ballgame for me.So far I've added a couple qts. of coolant to the reservor,but its slowly leaking out.Any possibility it could be coming from somewhere else?All the hoses and rad seem to be good,car only has 15,500 mi.Any suggestions,head gasket change is a pretty good sized job.
Old Sep 21, 2006 | 12:32 PM
Skrud13's Avatar
Skrud13
I am interested in this one also....I think I may have the same trouble on my vette.
Old Sep 21, 2006 | 01:01 PM
ultraviolet70's Avatar
ultraviolet70
Mine appeared to be the same thing, but it was actually the rear corner of the intake leaking and
running a trail down along the back of the head. Maybe you'll get lucky as well and that's all yours will be. I'd clean it as best as you can and reinspect.
Old Sep 21, 2006 | 02:11 PM
RRT vette's Avatar
RRT vette
This quote I would follow. Clean it good back there in a big area and start it up and with a flashlight, see if you can tell where is may be leaking from. This I would do before doing anything else. Either intake manifold gasket or head gasket, it's not the easiest job.
Old Sep 21, 2006 | 03:29 PM
chevy bob's Avatar
chevy bob
Thanks,that all makes good sense,but the problem is I can't even get my hand in between the cylinder head and firewall.I can't really even see much back there.It's loaded with wire looms,tubing,plug wires,ect.thats waht makes this such a b_ _ _ch.I did notice a slight oder of burnt oil after driving the car,wouldn't this indicate an intake leak?Thanks again
Old Sep 21, 2006 | 11:48 PM
ARatty385's Avatar
ARatty385
I agree with UltraViolet. My coolant leak came from my intake as well. If your knowledgeable about the TPI's it helps. If you are mechanically inclined it should only take a day or two max to tear down and rebuild. They really aren't that bad to take apart, just time consuming. Label everything if your not familiar. Good luck.
Old Sep 22, 2006 | 12:07 AM
19vette80's Avatar
19vette80
it isnt that bad just make sure you mark all hoses and vacum lines. I use a number system.
Old Sep 22, 2006 | 07:20 AM
chevy bob's Avatar
chevy bob
O.K. the general concensus so far is that its an intake manifold leak,which makes the job a little better.I've learned from previous posts on the forum that the intakes on these C-4's are noted for leaks on the backside.If I opt to do this job,what gaskets will I need beside intake,plenum,and distributor?Should I get these from the dealer or elsewhere?Any tips on doing this job by those who have done it,would be appreciated.Thanks
Old Sep 22, 2006 | 08:42 AM
RRT vette's Avatar
RRT vette
Off the top of my head...you will need intake manifold gasket set (only use the side gaskets and not the end gaskets...the ends will need just RTV). Plenum and runner gasket set and a distrubitor gasket (All Felpro and use "The Right Stuff"). Also when you disconnect the fuel lines it would be a good idea to replace the o-rings with brown fuel o-rings and not black ones. It's been a while, so maybe others just finished doing this and can be more detail. Also helps to have a book to follow the steps.
Old Sep 22, 2006 | 08:56 AM
aminnich's Avatar
aminnich
You can get rolls of different colored electrical tape at Lowes/Home Depot. Put different colors on your lines before you take it apart, then take pictures. When it goes together you will have no problem getting the right line on the right fitting.
Old Sep 23, 2006 | 11:56 AM
chevy bob's Avatar
chevy bob
Default coolant leak found
Thanks to everyone who chipped in,I found the leak,and its not going to be a bigee!Its the hose going to the oil cooler,which is why I had coolant all over the oil filter.Looks like I dodged a bullet.I would highly recomend having a coolant pressure tester in your toolbox,it saved me.
Old Sep 23, 2006 | 09:58 PM
LS6 Motor's Avatar
LS6 Motor
Indeed an easy one, BUT, don't be surprised if you need to do the intake before long, it is typical with the L98 motors
Old Sep 24, 2006 | 04:31 AM
JTHVETTE's Avatar
JTHVETTE
Default coolant leak???
This is follow up suggestion to all who have leaks in your cooling systems that you can't seem to find. Buy or borrow a "hand pump" style radiator/cooling system leak tester. You can pressurize the whole cooling system with engine off. This will find your leak most of the time.
If it is leaking into the combustion chamber you can pull the sparkplugs and check for coolant. If it is leaking into the crankcase the oil will be "milky" looking.
That's my 2 cents,
JTHVETTE
Old Sep 30, 2006 | 02:03 PM
Skrud13's Avatar
Skrud13
I was installing a new exhaust sytem last night and noticed that there is a small drip of coolant coming from what looks like the rear port on the exhaust manifold right above the oil cooler. I know that the head and the rear of the intake are right near there, but it really looks like it is coming from exhaust manifold.
Is that even possible????
What would cause that? Head gasket?
To coolant leak
