B&B Triflow install pictures needed
Old Sep 22, 2006 | 08:25 PM
mothersworry's Avatar
mothersworry
Default B&B Triflow install pictures needed
Does anyone some detailed B&B triflow pictures they can share? I need some from under the car. Does anyone have a set of instructions they can send me?
Thanks in advance.
Old Sep 23, 2006 | 09:07 AM
sonomacrew01's Avatar
sonomacrew01
what size system did you purchase? Myself along with others have had clearance issues. I had to alter the muffler hangers and purchase four shorter springs to lower the exhaust to clear certain areas. After the system was installed and aligned, I tack welded with stainless wire, removed the whole system and welded all the joints.
Old Sep 23, 2006 | 05:46 PM
mothersworry
Your pictures were extremly helpful. Got the system installed today and it sounds and looks great. I had to weld a 12 inch connector on the passenger side and flare the driver side. Do you have any vibration problems around the back glass latch?
Old Sep 23, 2006 | 06:32 PM
BBBAD94ZR1's Avatar
BBBAD94ZR1
Default B@b
Here is my zr1.
http://www.corvettevalley.com/galler...ze/big/cat/552
Ray
Old Sep 24, 2006 | 04:25 AM
DieL's Avatar
DieL
Is that vibration happening around 1800-2200 rpms ? Welcome to the world of B&B resonance...
Old Sep 24, 2006 | 11:43 AM
mothersworry
No the vibration happen above 3000. I am good in the lower RPM ranges
To B&B Triflow install pictures needed
