Collapsed radiator hoses
Old Sep 22, 2006 | 10:23 PM
VinceAD's Avatar
VinceAD
Default Collapsed radiator hoses
I had my 91' (L98) A/C converted over to the newer system today. I noticed tonight that my upper and lower radiator hoses are collapsed.
Does anyone know if the A/C conversion could have caused the hoses to collapse?
Thanks!
Old Sep 22, 2006 | 10:44 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
Old Sep 22, 2006 | 10:50 PM
redrose's Avatar
redrose
i've seen a number of lower hoses collapse, never an upper, its just an age/ heat thing, nothing to do with a/c....a car that runs ok under light loads but overheats if you twist it up may have a lower hose collapsing-- sitting still with the engine warmed up and revving the engine you can see it happen.
Old Sep 22, 2006 | 10:52 PM
VinceAD's Avatar
VinceAD
Thanks for the input, I'm going to change them out this weekend.
Vince
Old Sep 23, 2006 | 10:56 AM
90convertible for me's Avatar
Cruising
I have a 90 convertible. My upper radiator hose also collapses when it cools. I thought it needed replaced so did so. It didn't make any difference. The new one also does it. I think it is because there is not a spring inside the hose to support it. It doesn't seem to cause any problem as it opens up when the engine is running warmed up.
Old Sep 23, 2006 | 11:12 AM
C4Crazy787's Avatar
C4Crazy787
Check your cap and line to the coolant reservoir.
Your hose's are collapsing because the cap or the line will not allow any/enough coolant return in to the system upon cooling.
Good Luck
Old Sep 23, 2006 | 11:17 AM
Ttime's Avatar
Ttime
My friend's did that too. Check your overflow tank to see if it's fuller when it cold.
I change his radiator cap and it corrected the problem.
Old Sep 23, 2006 | 02:55 PM
FF1wms's Avatar
FF1wms
St. Jude Donor '11-'12-'13
Good Luck
Old Sep 23, 2006 | 03:10 PM
ultraviolet70's Avatar
ultraviolet70
Replace your cap.
Old Sep 23, 2006 | 07:18 PM
VinceAD's Avatar
VinceAD
Thanks to all on the radiator cap thing, I'll try that and see what happens. I couldn't find any hoses in stock in town today anyway.
Vince
Old Sep 23, 2006 | 08:09 PM
LS6 Motor's Avatar
LS6 Motor
Also, while your in there, and depending on the age, you may want to consider doing the thermostat, just my .02$ worth
To Collapsed radiator hoses
