holley stealth ram
Old Sep 23, 2006 | 09:20 AM
smokeshow's Avatar
smokeshow
Default holley stealth ram
i know the hsr wont fit under a c4 stock hood but i seen somewhere that someone was making custom hsr plenums to fit under the stock hood duz anyone know where i can get one ,thanks
Old Sep 23, 2006 | 10:32 AM
Slalom4me's Avatar
Slalom4me
GrumpyVette offered fabricated plenums in 2003. JoBy has a thread
detailing his work to fit the stock volume HSR plenum down over the
runners. LD85 modified an HSR plenum this summer with fairly
extensive machine work and welding - it is operational but he has
remarked that he intends to revisit the plenum over the winter season.
SloRVette has a stock dimensioned HSR with an opening in the hood.
A ToledoPro/Melrose 2-3/4" hood should fit over a stock HSR. In my
opinion, an HSR on an L98 ought to have the runner length extended
through the addition of divided spacers between the runners and the
plenum.
Here is a thread with some items that may be required for the install.
ACCEL complete Super-ram kit .
Use the Advanced Search to view the threads mentioned above. Enter
Stealth Ram and click 'Archives'.
Old Sep 23, 2006 | 10:37 AM
Slalom4me's Avatar
Slalom4me
Incidently - what finally happened on the sale of your Super Ram?
*F.s Accel Super Ram W/bbk 52mm Tb
Old Sep 23, 2006 | 07:05 PM
LD85's Avatar
LD85
Frank has some Grumpy style plenums still.
http://www.fuelinjectorclinic.com/contactus.htm
Old Sep 23, 2006 | 07:11 PM
LD85's Avatar
LD85
Originally Posted by Slalom4me
LD85 modified an HSR plenum this summer with fairly extensive machine work and welding - it is operational but he has
The Stealth is running very nicely I must say. I went to the drag strip a week ago but it was a rainout. I will be in Chicago this Wednesday but hope to get to the track in the next couple of weeks before the season ends.
BTW, from @ 3500 it pulls very very strong! All the way up to 140MPH, don't ask me how I know
It will take me quite a bit of time to machine a sub plate with the bell mouth and 2" adder in the floor of the plenum, the rest is just fab-aluminum welded to the base, if the track runs turn out well or comparable to the Miniram times that I had before, then I wont waste anymore time on the plenum.
Old Sep 23, 2006 | 08:52 PM
smokeshow's Avatar
smokeshow
Default still got it
still got it ,lots of intrest but no taker yet
Old Sep 23, 2006 | 11:47 PM
Slalom4me's Avatar
Slalom4me
and 2" adder in the floor of the plenum...
Rather than trying to machine the profile, why not use aluminum rod stock?
Say 3/8" or so in dia.
This would be easy to shape and a cinch for 'ol RJ to join to a riser made
of sheet stock. Stick to the K.I.S. principal - from what I've seen so
far, you could be done and on the road inside of two hours, three tops.
Old Sep 24, 2006 | 03:01 AM
smokeshow's Avatar
smokeshow
Default how much?
any idea how much he sells those plenums for .i bought the stealth ram today and it is just under 10 inches tall ,how tall can you go on the vette before it hits the hood .how much shorter are those modified plenums.i can make it my self ,but i would rather buy one,anyone buy one from these guys ?and hows the fit and how much duz he sell them for.thanks for all your help
Old Sep 24, 2006 | 07:36 AM
LD85's Avatar
LD85
Dimensional info here
http://forums.corvetteforum.com/show...light=LD85%27s
He sells it complete, ready to bolt on, already powder coated. The last time I spoke with him, he had the parts on the shelf but not fully assembled.
Old Sep 24, 2006 | 12:05 PM
LD85's Avatar
LD85
The lip can be machined with a radius cutter, that's hot really a big deal for me, I am more concerned about the overall design and after have the resonance issues with the lid, I want to use at least 3/16 thick material.
Adding 2" to the plenum floor takes the top of the bellmouths virtually up to the bottom of the lid, so I need to lay it all out before i get started,
But in a nutshell, I think I will use a solid aluminum base with sheet metal sides and lid welded together.
Old Sep 24, 2006 | 02:08 PM
smokeshow's Avatar
smokeshow
Default you do some nice work
that was the info i was looking for ,you did a great job on yours ,any news from holley about them releasing a plenum for the vette .because from what i can see their is a big demand for it ,or you can start making them and selling them ,thanks for all your info and soon im going to modify mine and if its not to much trouble i might pm you along the way for advice ,thanks
Old Sep 24, 2006 | 02:49 PM
LD85's Avatar
LD85
thanks, email me any time!
To holley stealth ram
