hatch strut removal
Old Sep 23, 2006 | 02:26 PM
redvetteC4's Avatar
redvetteC4
Default hatch strut removal
I am going to take these off yet do not see how to accomplish this. I know its easy and I could figure it out with just tinkering with it but thought it would be easier for someone to take 10 seconds and tell me the best way. TIA
Old Sep 23, 2006 | 03:03 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
A 16 oz. ball peen should make quick work of it...... Look on the ends and you'll see the retaining clips. Nothing to it.
Old Sep 23, 2006 | 08:31 PM
LS6 Motor's Avatar
LS6 Motor
Use a small flat blade screw driver, and slip it under the clip in the center. Make sure the clip doesn't take off on you. When you get the strut off, push the clip back in. As a piece of advice, use a 2x4 to hold the glass up when doing these. It is extremely heavy when you remove both of them, and one strut won't hold it, or have someone hold the glass while you are doing the swap.
Old Sep 23, 2006 | 08:35 PM
flyinlow90's Avatar
flyinlow90
Good Info...Thanx
Gotta do mine soon.
Gary
Old Sep 23, 2006 | 10:51 PM
Sam Lam's Avatar
Sam Lam
Right on! The comment on the 2 X 4 is sound advice.
Old Sep 23, 2006 | 11:45 PM
LS6 Motor's Avatar
LS6 Motor
I found out the hard way Bob
Old Sep 23, 2006 | 11:52 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Yea, just replaced mine from Napa, and after install could not lower the hatch glass, called napa and they said that it was the right part number, so had to remove them, call Chris @ Superior and he's sending a set of GM, sometimes you just have to bite it and get GM/Delco
Old Sep 24, 2006 | 12:45 PM
redvetteC4's Avatar
redvetteC4
Thanks for the info guys I will make good use of it today!
Old Sep 24, 2006 | 03:35 PM
LD85's Avatar
LD85
How much did you pay for the hatch struts?
Old Sep 24, 2006 | 04:59 PM
redvetteC4's Avatar
redvetteC4
$0 Didn't get new ones I polished the old ones with 180 grit then 600 grit followed by a non-chrome metal polish. Looks great compared to the boring faded black paint that they had before. My glass does lift kind of slow and not all the way up but doesn't bother me enough to pay $50+ bucks on ebay.
Old Sep 24, 2006 | 06:47 PM
honda hunter's Avatar
honda hunter
I have a set I plan on installing as well. I was wondering what all it took to remove and install.
Old Sep 24, 2006 | 07:18 PM
redvetteC4's Avatar
redvetteC4
It simply takes a small flatheaded screwdriver which you will need to pry under the 1cm or so wide band of black metal that is at the very end of each side. When you get the clip pried up far enough the end will be released from the glass. Also, disconnect the wire for the rear defrost.
To hatch strut removal
