Cutted cat.. does it throw a code?
Old Sep 13, 2001 | 10:25 PM
Springer's LT4's Avatar
Springer's LT4
Cruise-In III Veteran
Default Cutted cat.. does it throw a code?
If I gut or remove my main cat on my 86, will it through any type code?
Thxs
Jim
Old Sep 13, 2001 | 11:20 PM
TA's Avatar
TA
Default Re: Cutted cat.. does it throw a code? (two-tone86)
no codes set on mine, it's been almost a year. That is if my assumption is correct that a "cutted cat" is the same thing as a "gutted cat" :jester :jester
[Modified by TA, 10:21 PM 9/13/2001]
Old Sep 13, 2001 | 11:43 PM
Nomar116's Avatar
Nomar116
Shouldnt throw a code, but mine does throw a code 32 intermintently because of lack of Back pressure I believe.... I wouldnt worry about it though, if you either leave the precats and/or leave the exhaust tube connected to the cat youll be fine.
Paul
Old Sep 14, 2001 | 12:11 AM
NX1991's Avatar
NX1991
Default Re: Cutted cat.. does it throw a code? (Nomar116)
mine throws a 44....but no harm done..
Old Sep 14, 2001 | 12:33 AM
Marcho Polo's Avatar
Marcho Polo
2023 C8 of the Year Winner - Unmodified
2020 Corvette of the Year Finalist (stock)
2019 C7 of Year Winner (stock)
Former Moderator
Cruise-In I-II-III Veteran
on an '86 I doubt that it would throw a code. I've heard that for some reason 1990 and 1991 cars are more sensitive and will throw a code.
Old Sep 14, 2001 | 02:35 AM
pablocruise's Avatar
pablocruise
Mine hasn't. Someone said that some backpressure is desireable. Anyone? :confused:
Old Sep 14, 2001 | 04:19 AM
Stratocaster's Avatar
Stratocaster
Default Re: Cutted cat.. does it throw a code? (89 Paul in cal)
Codes wont be visual until 97 on (i think). C4s with post cat sensors (OBD II) will issue a code, but will not illuminate the SES... Those vehicles that do not use post cat sensors will not set codes.
The critical question is will the issuance of a fault code affect performance? Yes and no, depends on year according to different sources. I do know that the C4 OBD IIs will not adjust fuel trims based upon discreps between pre and post cat sensors... Pre/Post cat discrep may result in poor touring performance on newer vettes from others I have spoken to, but WOT will not be affected. Pre/Post cat discrep on OBD IIs should not result in either poor touring or WOT performance...
The 89 is not an OBD II PCM so you shouldnt see any issues I would think.
Old Sep 14, 2001 | 04:27 AM
Stratocaster
Default Re: Cutted cat.. does it throw a code? (Stratocaster)
Hey, dont gut the cat unless it is already damaged. Gutting cats gain you mid range performance, but if you are familiar with Bermouli (sp?) equations for fluids, going from a particular diameter to a larger one, then back to the particular diameter creates turbulence. You never attain the higher RPM performance that you would think you should. Gutting a cat would never equal that if you just replaced the cat with a test pipe of like diameter of the rest of the exhaust.
People do see better performance for gutting a cat, but a test pipe performs better. and when you get down to it, swapping out a test pipe for the cat during inspection just assures that you pass both the visual and sniffer tests.
Old Sep 14, 2001 | 10:13 AM
Springer's LT4
Don't have to worry about any inspections here... I would most likely be using a test pipe.
If I decide to keep my car, I'm thinking of removing all the cats and using a power effects system on the rear. Hopefully I can find an exhaust shop here in the Tampa FL area that will bolt a converter on ,but leave it very loose so I can swap it out with a test pipe. Of course, replacing the front Y may not be worth it at the moment if I'm considering building the engine and need headers.
Old Sep 15, 2001 | 01:07 AM
GRX's Avatar
GRX
My '85 doesn't set a code.
To Cutted cat.. does it throw a code?
