Roller rockers. Why not s.a.?
Old Sep 24, 2006 | 01:57 PM
ultraviolet70's Avatar
ultraviolet70
Default Roller rockers. Why not s.a.?
I'm just wondering why it is usually suggested when changing over too a full roller rocker to install guide plates and hardened push rods rather than going with self aligning? Is there an advantage of one over the other?
Old Sep 24, 2006 | 03:03 PM
STL94LT1's Avatar
STL94LT1
I'm running Comp Cams Pro Magnum 1.6 self aligning rockers in my car.
Old Sep 24, 2006 | 03:18 PM
ultraviolet70
I'm just trying to figure out what the advantage running hardened pushrods and guide plates is over self aligning rocker arms is. I mean staying with self aligning rocker arms requires only the purchase of rocker arms, so why go the other way?
Come on some one out there has to have a reason why they spent the money to buy all those parts instead of just the arms.
Old Sep 24, 2006 | 05:18 PM
STL94LT1's Avatar
STL94LT1
A few months ago Popular HotRodding/Hot Rod had an article stating that there was an advantage to running S/A rockers. I don't remember what they said, will see if I can find the article.
One advantage of non S/A rockers would be you can get N/A's in a 7/16 stud size opposed to the 3/8 studs for the S/A.
As far as cost, S/A rockers are quite a bit more expensive than the non S/A's. The cost will probably be about equal with buying the pushrods and guide plates.
Old Sep 24, 2006 | 05:20 PM
VenkmanP's Avatar
VenkmanP
Google is your friend.
Old Sep 26, 2006 | 04:39 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default Rockers
There is less friction with S/A rockers. but the other thing is :
using guide plates raises the stud up the thickness of the guide plate so there is the advantage of using longer pushrods to realign your rollers in the center of the valve tip if you're using poly locks and the stud seems too short for your comfort level.
To Roller rockers. Why not s.a.?
