best injectors
Old Sep 24, 2006 | 09:55 PM
jimmya's Avatar
jimmya
Default best injectors
ok, i know there is probably a thread with this already, but what is the best injector for my stock/slighty modified 1991 l98 vette.? 22s are factory, some people are suggesting 24s. will going to 24s hurt the fuel mileage. i know its not a big priority in a vette, but i have always been amazed at the fuel mileage they get. im looking at msd, ford motorsports, and accel. also, if i go cheapo, oreilys or autozone?
Old Sep 24, 2006 | 11:55 PM
LS6 Motor's Avatar
LS6 Motor
I have Bosch 22.5 lb units in mine, BUT, I only have a Magnaflow exhaust, everything else is stock.
Old Oct 10, 2006 | 01:02 AM
67RivGS's Avatar
67RivGS
I was also looking for some input and advice on this subject but it does not look like there is going to any forthcoming?
Old Oct 10, 2006 | 09:05 AM
Wheelman's Avatar
Wheelman
Get the Ford Motorsports 24lb injectors and a Holley AFPR for your L98.
Old Oct 10, 2006 | 09:07 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Do NOT go Accel or Python. They're garbage.
Old Oct 10, 2006 | 11:00 AM
rtammes's Avatar
rtammes
7th Gear
Not to Hijack your post but are these the right Ford-SVO injectors everybody talks about?
http://www.1320hp.com/products/produ...UE&SECTION=150
I want to order them, but since I live in the netherlands, I want to make sure they will fit my '85 corvette...
Old Oct 10, 2006 | 11:16 AM
RRT vette's Avatar
RRT vette
I remember from your previous thread that the injectors ohmed good and you were having a problem with signal on the passenger side. Are the injectors leaking? Are you changing them for future purposes because they are high failure rate Multec injectors? Did you find the problem with the wires?
If the injectors are leaking, I would go with the stock lb rating. JMO
Old Oct 10, 2006 | 02:29 PM
vader86's Avatar
vader86
Ford 24lbs with a Holley AFPR.
Do not buy Accel
Old Oct 10, 2006 | 03:07 PM
zo1boy's Avatar
zo1boy
Do not buy Accel
Will those be good on a slightly modded L98?
Old Oct 10, 2006 | 04:20 PM
vader86's Avatar
vader86
Yes.
Old Oct 10, 2006 | 05:30 PM
yellow dragon's Avatar
yellow dragon
i just installed bosch 22.5's on my slightly modded (exhaust, head porting) L98, car runs great!! heard bad things about ordering from
five-0-performance, order from tpis.com, brand new 360$
Old Oct 10, 2006 | 07:53 PM
Wheelman's Avatar
Wheelman
Do not buy Accel
Hey look, I have an echo
To best injectors
