87 ps pump
Old Sep 26, 2006 | 06:45 PM
Jim D's Avatar
Jim D
Default 87 ps pump
Do you have to take the pulley off to remove the power steering pump. Thats what the manual says, thanks Jim.
Old Sep 26, 2006 | 08:43 PM
Coupe89's Avatar
Coupe89
St. Jude Donor '05-'06
With a PS pump pully remover.
Old Sep 26, 2006 | 11:02 PM
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
Yeah take it off while its still bolted to the car/engine,and re press it on to the new pump bolted onto the car/engine...if you cant do it that way,you need a bench vise to hold the pump and with the proper tool,take pulley off/repress it on to the new pump in bench vise.
Its very easy to do!
Old Sep 27, 2006 | 06:33 AM
rons85's Avatar
rons85
, But - the answer to your Question is: No, the pump can be removed from the engine with the pulley on it. BTW - I find it easier to remove the pulley from the pump (with a puller and a bit of heat from a torch) After it's out of the car and in a bench vise.
To 87 ps pump
