Cam Size Question
Old Sep 29, 2006 | 01:36 AM
garycr14's Avatar
garycr14
Default Cam Size Question
Does anyone have any idea on what is the max size cam I can go with and still be able to pass the California sniff test. I have heard the the LT4 hot cam will not pass, so I will need something between stock & the the hot cam. I would like to squeeze another 25 - 50 hp &ft.lbs out of the car when I rebuild in the next few weeks.
The motor will have AFR 195 heads.
Thanks!
Old Sep 29, 2006 | 02:08 AM
vader86's Avatar
vader86
LT4 hotcam will pass. You just need to find the right chip tuner to make it so.
Old Sep 29, 2006 | 04:14 AM
SK.LT1's Avatar
SK.LT1
Old Sep 29, 2006 | 05:28 AM
93 ragtop's Avatar
93 ragtop
I passed the nor. va. test. Not sure how it compares to California's test. They put my car on the dyno test at 15 and 25 mph and sniffer test. My chip was done by Alvin at www.pcmforless.com See signature for complete list of mods.
Old Sep 29, 2006 | 06:23 AM
CALI C4er's Avatar
CALI C4er
California is the toughest in the USA.
Old Sep 29, 2006 | 10:39 AM
Red Tornado's Avatar
Red Tornado
exactly
so do this:
Originally Posted by 93 ragtop
...My chip was done by Alvin at www.pcmforless.com See signature for complete list of mods.
Old Sep 29, 2006 | 11:01 AM
STL94LT1's Avatar
STL94LT1
I passed Missouri's emissions test with my Comp Cams custom grind camshaft. Specs: 224/230 605/622 112.
Old Sep 30, 2006 | 12:01 AM
garycr14's Avatar
garycr14
California does have the strickest emission regs in the country, and a real pain to deal with. I want to try and push the envelope a bit, but I was told by a highly regarded Corvette mechanic the the hot cam will not pass. I don't need to get that aggressive with the cam as the heads have already given me a pretty good power boost, and I just need an extra 25 - 50 hp/ft.lbs. to reach my objective. I am hoping to find anyone out there with some experience with CA.
Thanks for your insights.
Old Sep 30, 2006 | 01:23 AM
black_89_vette's Avatar
black_89_vette
I just disconnected my ESC wire at the brake booster. Runs car off base timing, emissions are way less.
To Cam Size Question
