Taillights.
Old Sep 29, 2006 | 07:49 PM
csiki22's Avatar
csiki22
Default Taillights.
Hello,how do I remove the
taillamps from my 84?
Old Sep 29, 2006 | 07:58 PM
c4cruiser's Avatar
c4cruiser
Remove the license plate. Remove the backup lamp assembly. Reach in behind the tail lamp and remove the two 10mm nuts holding the inboard lamp assembly to the rear facia. Remove the bulb housing. Reach thru the inboard lamp hole and remove the two nuts on the outboard lamp assembly.
I would remove all four tail lamp housings and replace the bulbs with Sylvania "Long Life" 1157 bulbs. The factory bulb sockets will have a dried up dielectric grease in there that will most likely break the glass part of the old bulb. Remove the bulb and scrape out all of the old yellowed grease and clean the contacts at the base of the socket. Apply a thin film of new dielectric grease (Permatex makes a small tube that works fine) and install the new bulbs.
Old Sep 29, 2006 | 08:01 PM
csiki22's Avatar
csiki22
Default Thanks
Thanks for the info!
Old Sep 29, 2006 | 09:23 PM
Grease Monkey's Avatar
Grease Monkey
From: Hampton, VA Yea, i'm a redneck... but you love it
Cruise-In 8-9 Veteran
aka/Trunk Monkey/Banned For Life/Corvette For Life
i hope that you have skinny arms, i hate doing it. its hard to reach
To Taillights.
