X-ram
Old Sep 29, 2006 | 08:10 PM
csiki22's Avatar
csiki22
Default X-ram
How well does the X-RAM
really work.I am talking stock motor,
3.73 gears, auto.I am considering
buying one for my 84.
Old Sep 29, 2006 | 08:20 PM
CFI-EFI's Avatar
CFI-EFI
Some people like them and several have taken them off. I have a hard time imagining it's any better than my home ported manifold. The ported stock manifold is the only modification to my worn out, all original, engine.
RACE ON!!!
Old Sep 29, 2006 | 08:33 PM
csiki22's Avatar
csiki22
Default Manifold
You drag race?How much differance
did it make in the 1/4 mile?(your
ported manifold that is.)
Old Sep 29, 2006 | 08:40 PM
elkabong's Avatar
elkabong
If the motor is stock you would better off with a ported crossfire manifold. I had a XRam on my stock motor and I took it off and installed a ported stock manifold. The performance was much better with the ported manifold. Now I have a 383 and the XRam is being used. That should give you a quick comparison.
Old Sep 29, 2006 | 08:45 PM
csiki22's Avatar
csiki22
Default Porting
So you opened up the stock
manifold so it would match up
to the head?I relize the stock
manifold is like really small port
wise.I thought they were
"unportable"?
Old Sep 29, 2006 | 09:24 PM
Grease Monkey's Avatar
Grease Monkey
From: Hampton, VA Yea, i'm a redneck... but you love it
Cruise-In 8-9 Veteran
aka/Trunk Monkey/Banned For Life/Corvette For Life
"unportable"?
i had heard that too
Old Sep 29, 2006 | 10:01 PM
GKK's Avatar
GKK
On the underneath side of the Stock crossfire intake manifold you'll see the Runner castings. The Runner castings are shortened and ported also, the egr passage is ground down.
Here's a picture of the procedure. http://www.technovelocity.com/chevyh...rt_polish.html
Go to http://www.crossfire.homeip.net/ for more crossfire information.
Old Sep 29, 2006 | 10:14 PM
csiki22's Avatar
csiki22
Default Thanks
Thanks for the info!Great link!
Awesome pics.
Old Sep 29, 2006 | 11:31 PM
SHINOBI-X's Avatar
SHINOBI-X
"unportable"?
That intake has tons of material to port away
CFI-EFI says his dropped his car about .6 tenths in the 1/4. I ported mine and I got about .4 drop in ET myself. I could have gone deeper but had so much time in it,I just had to put it on and try it!
Got me from around 15.1 to 14.7 ET's
Old Sep 30, 2006 | 01:49 AM
kopbet89c4's Avatar
kopbet89c4
This is what kills a stock CFI Vette.
Old Sep 30, 2006 | 01:57 AM
SHINOBI-X's Avatar
SHINOBI-X
And the stone-aged ECM that isn't tunable either
Old Sep 30, 2006 | 06:29 AM
silver84's Avatar
silver84
Shinobi-X,
>That intake has tons of material to port away<
how much larger, can the runners be changed to?
what cross section area?
any numbers?
Old Sep 30, 2006 | 10:29 AM
SHINOBI-X's Avatar
SHINOBI-X
Originally Posted by silver84
Shinobi-X,
any numbers?
See that picture Kopbet89 just posted? Look at the picture and notice you can see a gasket that was stuck and left its imprint on the intake manifold. Its already traced out for you and your ready to port Its probobly a 1204 size gasket but you can inlarge it to a 1205 size gasket. I did and don't just inlarge the intake port either,go deeper and deeper.
You can also port the intake side that underneth the top plate the throttle bodies sit on aswell.
Old Sep 30, 2006 | 02:21 PM
CFI-EFI's Avatar
CFI-EFI
I picked up better than 6 tenths in the 1/4 mile. A month later I installed 2" bored TBs for NO additional gain. Unlike the link provided, I didn't touch my EGR passages. My EGR remains fully operational. Despite NOT removing the EGR channel, inside the manifold, I ended up with a 3 pound coffee can, nearly full of grindings. There isn't a lot of surplus material in those runner, but I got most if it, and some that wasn't. I love it when someone says something like "unportable". I am pleased with 13 second 1/4 mile times in a 160,000+ mile, oil burning, stocker.
RACE ON!!!
Old Oct 1, 2006 | 10:05 AM
qws's Avatar
qws
I have the x-ram on a stock motor, with only a few mods. (see my sig). I also have a dyno under my corvette pics with the X-ram on. It should have been higher that day. My fuel was running rich. I have since bought a set up so I can adjust fuel psi. I also have a stock 84 dyno that I need to get posted soon so that people can see the comparison of the stock manifold vs. X-ram.
Personally I like it, expensive YES, worth it is in the eyes of the beholder.
Old Oct 1, 2006 | 10:38 AM
kopbet89c4's Avatar
kopbet89c4
RACE ON!!!
What was the trap speed of the original vs. ported? That is a damn big improvement!
Old Oct 1, 2006 | 08:07 PM
CFI-EFI's Avatar
CFI-EFI
I was pleased by the results of my extensive efforts. That is a tough question. It has been years. I'll have to dig through old log books to see if I can find it. my guess would be 3- 4 mph. Presently I trap in the 98 mph range, but the car is faster, now than when I installed the manifold. Since I started racing, I have reduced my ETs by better than 2 seconds.
RACE ON!!!
To X-ram
