Got the vette back together
Old Oct 1, 2006 | 09:01 AM
93 ragtop's Avatar
93 ragtop
Default Got the vette back together
Well I have the diff. back together and in the car. Only problem I noticed is a slight oil leak where the weld was done on the carrier. For now, I am going to monitor it, and leave it until winter.
But I must say, this diff, is totally quiet. I drove it about 25 miles and there is no noise at all. The other 2 had richmond gears so that may have been the cause of the noise with them. This one has a new case assy. and dana 3.73 gears. The car rolls easier, ( less engine drag) but I am not sure how much it will hurt performance. Im going to the track wednesday to find out. Oh, and I went back with 1 additive and mobil 1 75-90 oil. Thanks to everyone who gave me input on getting the car back together.
Old Oct 1, 2006 | 11:09 AM
obnoxus's Avatar
obnoxus
Might try a little epoxy, or JB weld on the leak to hold you over.
I cant believe the rolling resistance on these cars,,,, I was highly suprised when I got my first 94.
I assume from your post its mostly in the rear ends.
Curious to see if it makes a diff at the track.
Old Oct 1, 2006 | 12:03 PM
toptechx6's Avatar
toptechx6
Best of luck at the track hope this one stays together.
Old Oct 1, 2006 | 12:38 PM
Fancyazz's Avatar
Fancyazz
3.73's should be only a tenth or 2 max raise in ET im guessing.
Old Oct 1, 2006 | 01:22 PM
SHINOBI-X's Avatar
SHINOBI-X
Awsome RAG,that will help going to a lower gear with your SC project.
sooooo......when you decide to go to a straight axle you can always make some $$$ and sell it to me!
Old Oct 2, 2006 | 06:31 AM
93 ragtop's Avatar
93 ragtop
I was thinking about jb weld or one of those brazing rods made for alumium.
The rolling resistance that I am talking about is mostly due to the engine rpms of the 4.09 vs 3.73
93 ragtop's Avatar
93 ragtop
Thanks, and I plan on staying on top of oil changes.
Old Oct 2, 2006 | 06:33 AM
93 ragtop's Avatar
93 ragtop
Thats about what I figure, but 1 to 2 tenths is a lot when you are setting on the 11-12 sec. line. But eventually the supercharger addition should take care of that.
Old Oct 2, 2006 | 06:34 AM
93 ragtop's Avatar
93 ragtop
I will try to keep you in mind. Hopefully this one will not break and it will last awhile.
To Got the vette back together
