meziere elect. wp...
Old Oct 1, 2006 | 12:46 PM
JJ 86's Avatar
JJ 86
Default meziere elect. wp...
those who are running these pumps do you have any pics of them installed? Is it nessisary to remove the water pump drive gear or is it okay to let it spin?
Old Oct 1, 2006 | 01:00 PM
STL94LT1's Avatar
STL94LT1
There are those who leave the water pump drive installed. I removed mine, didn't want another source for a possible oil leak.
Old Oct 1, 2006 | 01:12 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
I would think that without the pump to support the drive, it'd be difficult for the drive seal to hold for long. Besides, I wanted to remove mine so I could use a true double roller timing set.
Old Oct 1, 2006 | 01:42 PM
Ramrod92's Avatar
Ramrod92
Cruise-In II Veteran
Old Oct 1, 2006 | 01:48 PM
JJ 86's Avatar
JJ 86
What are you guys using to block off the drive hole left in the water pump housing? Would i have to get a different timing cover? If i remove the timing cover it would probably be a good time to upgrade the cam . How difficult is it to remove the timing cover?
Old Oct 1, 2006 | 03:42 PM
STL94LT1's Avatar
STL94LT1
I used a small freeze plug and JB weld to block off the WP drive hole, in both the water pump housing and timing cover.
You can use the same timing cover.
Yes, upgrade the camshaft.
To remove the timing cover, you have to pull the water pump, opti, balancer/hub, and drop the front of the oil pan.
Old Oct 1, 2006 | 04:23 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
I left mine in, and now, despite replacing all the front seals, I have oil on the front of my engine.
Old Oct 1, 2006 | 05:08 PM
JJ 86's Avatar
JJ 86
Anyone have pics of the install?
Old Oct 1, 2006 | 11:06 PM
sonomacrew01's Avatar
sonomacrew01
I took the timing cover and had an aluminum bung welded in place. I then removed the W.P. gear drive and installed a cloyes 9-3145 timing chain
http://pg.photos.yahoo.com/ph/design...4b.jpg&.src=ph
http://pg.photos.yahoo.com/ph/design...bd.jpg&.src=ph
Old Oct 1, 2006 | 11:08 PM
sonomacrew01
one more thing.. If you decide to do what I did, make sure you have someone who knows what they are doing when welding aluminum. Heat dispurses faster in aluminum and may distort the timing cover/ruin the opti/crank seals.....
Old Oct 2, 2006 | 01:28 AM
JJ 86's Avatar
JJ 86
Thanks. Anyone else have any pics of what it looks like installed in the car?
Old Oct 2, 2006 | 10:28 AM
JJ 86's Avatar
JJ 86
bump
Old Oct 2, 2006 | 11:43 AM
RCFguitars's Avatar
RCFguitars
Here are some pics of mine. I had it all summer, and I don't think my temp ever got over 180.
Old Oct 2, 2006 | 12:36 PM
JJ 86's Avatar
JJ 86
Did you remove the water pump drive shaft from the timing cover?
Old Oct 2, 2006 | 06:42 PM
sonomacrew01
I think you have to... Meziere supplys a freeze plug for the waterpump and the shaft would interfere.
Old Oct 2, 2006 | 10:27 PM
Hotred94's Avatar
Hotred94
I removed the wp gear and shaft to prevent future leaks. The seals can only take so much wobbling before they wear out and leak. Use the supplied freeze plug in the pump body, then jb weld a 50 cent piece into the timing cover hole. Two years coming up on my mod and no leaks.
Old Oct 3, 2006 | 12:41 AM
JJ 86's Avatar
JJ 86
Thanks for the replys!
To meziere elect. wp...
