Skip shift disconnect
Old Oct 2, 2006 | 06:44 PM
The Bus's Avatar
The Bus
Default Skip shift disconnect
I just purchased a 01 Camaro SS. Tomorrow I plan on disconnecting the skip shift connector on the tranny.I was told I needed a resistor. I looked in my 92 Vette service manual and the ECM feeds a relay for that circuit so there is no need for a resistor to fool the computer is the Camaro wired the same way?? Thanks to all who answer
Old Oct 2, 2006 | 06:52 PM
rodj's Avatar
rodj
You are correct on the Vette I believe most just unplug it .
Maybe the later setup actually has some ECM feedback
( to stop naughty people disconnecting it )
Old Oct 3, 2006 | 05:39 AM
Casethecorvetteman's Avatar
Casethecorvetteman
Can be disabled in the ECM settings. Have the ECM flashed to have it disabled and it wont do anything then. If you just unplug it on a later model like that i think it will set a DTC (im not sure though)
Old Oct 3, 2006 | 08:01 AM
GIJoe's Avatar
GIJoe
St. Jude Donor '08-'09
you might be better off asking that in the C5 tech since thats more closely related.
i know on my ZF6, I just unplugged the wire from the solenoid on the tranny and walah, no more skip shift and no error codes either.
Old Oct 3, 2006 | 11:50 AM
94ZR1's Avatar
94ZR1
St. Jude Donor '06
I believe a code will set if it is just unplugged also the plug ends will be unprotected
I got a CAGS eliminator from Lingenfelter Performance Engineering very cheap and it just plugs right in
To Skip shift disconnect
