GM Replacement Opti - Good or Bad?
Old Oct 2, 2006 | 08:23 PM
DonLT4CE's Avatar
DonLT4CE
Default GM Replacement Opti - Good or Bad?
About a month ago I read in a thread here that some people were getting bad replacement Optisparks from GM because they had changed the manufacturer of the internals from Mitsubishi to X? There were comments both ways. I can't find this thread now and was wondering if this was ever resolved.
I was going to change mine when I replace the crank seal, but am hesitant now. I would like to stick with the original equipment, rather than the other choices.
(96 LT4 - gen 2 Opti)
Old Oct 2, 2006 | 08:41 PM
sonomacrew01's Avatar
sonomacrew01
Didn't hear anything about the mitsubishi thing but I can tell you that after rebuilding my 93 LT1 with a gen 2 opti, I used a GM replacement. It threw a code 16 a few miles into it as a low res. pulse failure... Replaced with a MSD and all is well
Old Oct 3, 2006 | 05:47 AM
Casethecorvetteman's Avatar
Casethecorvetteman
Go with the MSD unit if youre going to replace it i reckon, i have yet to hear anything negative about it.....
Old Oct 3, 2006 | 08:42 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Use either a Dynaspark or an MSD Opti. Don't go with Accel.
Old Oct 3, 2006 | 09:06 AM
Casethecorvetteman
Oh hell no . Dont buy anything Accel!!!
Old Oct 3, 2006 | 11:23 AM
Huntervangolf's Avatar
Huntervangolf
Don't buy anything made by accel. I've tried accel stuff in some of my other hotrods. I use nothing but msd, plus accel colors brown and yellow? Not that colors matter on optisparks.
Old Oct 3, 2006 | 12:26 PM
bogus's Avatar
bogus
If GM did change the source of the optical part, it makes sense as the why they are experiencing huge failure rates... great, a cheap part that saves them 10.00... and costs them a fortune in warrantee claims. Makes great sense to me...
So you know, the Accel opti looks like junk, right out of the box... both the GM and the DynaSpark use sealed bearings... the Accel unit uses an oilite bushing. That bushing is guarenteeing a 60k mile replacement cycle.
Old Oct 3, 2006 | 01:57 PM
onedef92's Avatar
onedef92
Accel is ghetto garbage. Ditto for Python. Found that out the hard way. Never again.
Old Oct 3, 2006 | 03:04 PM
Kinkajou's Avatar
Kinkajou
OEM optis really suck!
Dynaspark seems to be a great investment.
Old Oct 4, 2006 | 04:04 PM
DonLT4CE's Avatar
DonLT4CE
OK - seems as if enough question on reliability to rule out OE - will have to decide now whwether to replace, or leave old one in at 62K miles. I see posts that some gen 2's last 3X my mileage, so will probably opt to stay with old. Thanks to all, and Bogus as usual, for input!
Don
Old Oct 5, 2006 | 07:45 PM
jonecap's Avatar
jonecap
I put a GM performance parts Opti in mine about 3,000 miles ago and it works great.
Old Oct 5, 2006 | 08:15 PM
Louis Bartay's Avatar
Louis Bartay
Default Opti
I have 75,000 miles on my 96 LT4 with the orginal Opti Spark. Guess I was lucky? I did see a GM rebuild kit, cap and rotor, might try that. Cheaper than a new one.
Old Oct 5, 2006 | 08:39 PM
bogus's Avatar
bogus
For the 1995-1996 LTx motors, they upgraded the hell outta the opti. Better sealing, better bearings, positive pressure venting... yea, 120k miles is not out of the question with a 2nd gen opti.
bogus's Avatar
bogus
fingers crossed.
Old Oct 5, 2006 | 08:40 PM
bogus's Avatar
bogus
fingers crossed.
Old Oct 6, 2006 | 07:39 AM
runner140*'s Avatar
runner140*
Yah, I have an origional in my 96' with 119000 on it. Any day now.
Old Oct 6, 2006 | 08:42 AM
onedef92's Avatar
onedef92
For $600 bones and the quality/performance you get, it's probably the best deal currently going.
Old Oct 6, 2006 | 03:54 PM
jonecap's Avatar
jonecap
I've got a buddy with a '94 LT1 Trans AM with 230,000 miles on the original opti and still counting
Old Oct 6, 2006 | 05:03 PM
USCG's Avatar
USCG
My OEM went 120k. The replacement over a year ago was OE and have never had a problem, in spite of my shortcomings (over-revving at the track).
To GM Replacement Opti - Good or Bad?
