88 coupe:
I believe I have to remove the front bumper to be able to change the $2.00 parking light bulb. This looks a little tricky for me to do - Has anyone found a different way to get to that light fixture?
No bumper removal necessary........you can change both the parking lamp and fog lamp from under the hood..........It's not really that hard but small hands help.
Thanks - you are right. The socket was covered by something and didn't look obvious - so I read the shop manual which said the fog light assembly required taking the bumper off - so I didn't try to see any way from inside to get to just the bulb. It's there - way easier now. Thanks a lot.
