TB Bypass
Old Sep 15, 2001 | 12:40 PM
dsky's Avatar
dsky
Default TB Bypass
do we need to run a bypass hose or can we cap off each end of the exsisting hose?
is that circuit needed for something else?
doug :jester
Old Sep 15, 2001 | 12:56 PM
Ron78Z&66Vette's Avatar
Ron78Z&66Vette
Default Re: TB Bypass (dsky)
I forget where the coolant is routed on an LT-1, but YES, it's definately needed.
Old Sep 15, 2001 | 11:53 PM
satyr7777's Avatar
satyr7777
Default Re: TB Bypass (Ron78Z&85Vette)
I REALLY need to do this, down here in TX, it could help quite a bit.
Old Sep 16, 2001 | 01:06 PM
Scott LeMuke's Avatar
Scott LeMuke
I bypassed mine a couple weeks ago. The car seems to run stronger to me now. It is my first mod. ( I started with the cheapest thing first.)
I simply connected the two hoses removed from the TB with a cheap ( a buck or two) coupler (and 2 hose clamps) that I got at the auto part store.
If you splice the two lines, it looks like it belongs that way. If you cap two ends, it looks tampered with. (Also, I agree with the other responses that the continuity in the coolant line should be maintained).
To TB Bypass
