Warn Tie Rod?
Old Oct 5, 2006 | 12:43 AM
slicked25's Avatar
slicked25
Default Warn Tie Rod?
I was getting a balanced and alignment done the other day and the guy said my front left tie rod needs replacing. I've been noticing slack in the steering and when I let go of the wheel she dives right. Now I looked up Tie Rods and need to know which was he talking about and is it hard to replace? I'm pretty sure he meant the outer Tie Rod End but need a little help. Thanks.
1984-96 Outer Tie Rod End
http://www.ecklers.com/product.asp?p...dept%5Fid=1839
1988-92 Inner Tie Rod End
http://www.ecklers.com/product.asp?p...dept%5Fid=1828
Old Oct 5, 2006 | 09:32 AM
Clay Assassin's Avatar
Clay Assassin
You likley need to jack up the car, and see which one is bad.
Wiggle the wheel, and see which one is allowing for the movement.
Thats the one you replace.
I havent done the front on my vette yet, but thye typically are not hard to replace.
Old Oct 5, 2006 | 11:19 AM
mikey whipreck's Avatar
mikey whipreck
The outer tie rod should have a wear indicator at the zerk fitting. I dont know the meaurements off hand for what is 'within range,' however. Those are easy to replace. You'll just need either a fork tool (which will ruin the old tie rod end), or a pitman arm puller, to get the old end off. The new one will just pull tight when you screw it on. Either way, you can get them cheap or free (if you rent them) at autozone.
I've never replaced the inners, so I have no advice on that...
Old Oct 5, 2006 | 11:49 AM
CFI-EFI's Avatar
CFI-EFI
You will have to ask him which he was referring to. Or you can check it out for yourself. On my car the inners went first. They can be a bear. Step one, is to remove the rack from the car. Follow your FSM from there. My rack had morning sickness, so I just replaced the whole thing. The inner (but not the outer) tie rod ends come with the rack assembly, exchange.
A well placed hammer blow is much more expedient and doesn't ruin anything.
RACE ON!!!
Old Oct 5, 2006 | 12:10 PM
AZC4Guy's Avatar
AZC4Guy
Warn tie rod... is it in danger? What does it need to be warned about?
Old Oct 5, 2006 | 12:45 PM
mikey whipreck
RACE ON!!!
haha, yeah that too.
Old Oct 5, 2006 | 01:23 PM
slicked25's Avatar
slicked25
It's the front left outter tie rod that's bad. But I assume you have to change the front right outter tie rod too?
Old Oct 5, 2006 | 01:31 PM
C4boy's Avatar
C4boy
You don't have to, but it's not a bad idea considering they're pretty cheap and easy to do. You should have no problem finding outers locally. You won't need a tuning fork, but you will need a front end alignment afterwards.
Old Oct 5, 2006 | 01:34 PM
CFI-EFI's Avatar
CFI-EFI
haha???
RACE ON!!!
Old Oct 5, 2006 | 03:10 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Warn makes good products such as winches and hubs. I'd think their tie rods would be of high quality, too.
Larry
code5coupe
Old Oct 6, 2006 | 03:15 AM
89Corvette6spdFX3's Avatar
89Corvette6spdFX3
Good thing it's an outer tierod. I've replaced an inner and they are a pain in the butt!
To Warn Tie Rod?
