Fuel Injector Cleaning
Old Oct 5, 2006 | 04:15 PM
lefoy84's Avatar
lefoy84
Default Fuel Injector Cleaning
Can anyone recommend a good fuel inj cleanning service. One that flow tests.
Old Oct 5, 2006 | 04:19 PM
RRT vette's Avatar
RRT vette
A lot of members seem to like Rich at http://www.cruzinperformance.com/fuelinj.html
Old Oct 5, 2006 | 04:28 PM
lefoy84's Avatar
lefoy84
Looks like he is down due to a death. Anyone else?
Old Oct 5, 2006 | 07:08 PM
williammackean's Avatar
williammackean
St. Jude Donor '07
How long is he down? Seems to me that a death should only take about a week's worth of production time.
Are you in that bad of a hurry? If so, you might as well go buy your own 3M injector cleaning kit at a local performance parts store. You can visually see if one is shooting more than another by putting each injector in a different clear glass and activating them. This can be done while all 8 are mounted to the rail. Attach the 3M cleaner canister which is pressurized @ 35psi and have at it. All you'll need is power. Find out how much juice is on your injecto installed and mimic it.
It'll cost you about $400 for the kit, but each canister is only $25 thereafter. Most folks just attach that to the fuel rail via Schraeder valve with the pump fuse pulled and let the engine idle out.
Old Oct 5, 2006 | 08:12 PM
lefoy84's Avatar
lefoy84
Thanks but I'll pass on 425$.
Old Oct 5, 2006 | 10:28 PM
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
Wow,didnt know that...Hope everythings Ok for him and the people involved...
Ive used him before and I highly recommend Rich.
Youll get everything done,flow specs sheets before and after,etc.I had a set done by him and couldnt be more pleased.
Sorry cant recommend others because I didnt have a need to use anyone else.I recently recommended a family member to use him for injector service he needed done and never heard of any problems using rich.
Old Oct 5, 2006 | 10:43 PM
mikey whipreck's Avatar
mikey whipreck
I'd recommend Rich above anyone... but if you can't wait:
http://www.witchhunter.com/index.php4
The person who runs that business is also on this forum occasionally.
Old Oct 6, 2006 | 06:03 AM
Joe C's Avatar
Joe C
thanks for the info/site - lots of good information -
Old Oct 6, 2006 | 06:57 AM
86PACER's Avatar
86PACER
Before I knew about Rich, I used TPIS. They charge a lot more than Rich does.
Old Oct 6, 2006 | 05:02 PM
Ramrod92's Avatar
Ramrod92
Rich is Da Man. Here's the report he did for a set I recently set him. RANSOME BERRY
6432 CARSON DR
OLIVE BRANCH, MS 38654
Date: 7-13-06
Vehicle: 92 CORVETTE
Model: 280 150 945
Injector serial #: 607131-607138
Preliminary Test Results
Test pressure = 43.5 psi Injector No.
1 2 3 4 5 6 7 8
Test 1. Injector Resistance 14.8 14.7 14.8 14.7 14.7 14.7 14.8 14.7
Test 2. Leak Down Test (Pass / Fail) P P P P P P P P
Test 3. Spray Pattern (Good / Fair / Poor) G G G G G G G G
Test 4. 60 Second Pulsed Flow Delivery (mL) 85 84 83 84 85 84 84 84
Test 5. 100mL Pulsed Volume 100 99 98 99 100 99 99 99
Test 6. 15 Second Static Flow (mL) 88 88 87 87 88 88 88 88
Test 7. 100mL Static Flow 0 0 0 0 0 0 0 0
Approximate pound-per-hour flow 30.1 30.1 29.76 29.76 30.1 30.1 30.1 30.1
Test Results After Service
1 2 3 4 5 6 7 8
Test 1. Leak Down Test (Pass / Fail) P P P P P P P P
Test 2. Spray Pattern (Good / Fair / Poor) G G G G G G G G
Test 3. 60 Second Pulsed Flow Delivery (mL) 86 87 85 86 87 87 87 87
Test 4. 100mL Pulsed Volume 99 100 98 99 100 99 99 99
Test 5. 15 Second Static Flow (mL) 90 90 89 89 90 90 90 90
Test 6. 100mL Static Flow 100 100 99 99 100 100 100 100
Approximate pound-per-hour flow 30.79 30.79 30.45 30.45 30.79 30.79 30.79 30.79
Parts Replaced
Pintle Caps Seals O-Rings Screens Hoses Clips
8 0 16 8 0 0
Comments
Tests performed at 0.700 specific gravity.
Old Oct 7, 2006 | 10:45 PM
mkstewet1's Avatar
mkstewet1
South Georgia Corvette out of Thomasville, Ga is a good place. They recently did mine. You can contact them through thier website. www.sgvette.com. Hope this is helpful to anyone in the area especially.
To Fuel Injector Cleaning
