have 87 hanger queen. drive maybe 1 hour ever 15 days. had inspection done today and failed as co was 1.83 and max was 1.20 at low speed {idle at 639}/ at 2500rpm passed fine. any suggestions??? problem is ?? thanks in advance for you help
instead of getting true duals (I don't know what kind of exhaust you got), but you should consider getting a cat-back system. Then, you can change the cats once a yr. Have 2 sets. 1 pair as your stock ones, and 1 pair that you got in junk yard, and knocked out ALL the insides. This way, you only have to change your cats once a year, and have "true duals" for the rest of the year.
