failed emission
Old Oct 6, 2006 | 02:18 PM
ghallam's Avatar
ghallam
Default failed emission
I have a 93 LT1 with 50,000 miles. Failed Arizona emission test. Both Carbon monixide and hydrocarbons failed. NOX passed. I have no codes in the computer and service engine light is off. Anybody know what I might look for first, or should I go to dealer?
Old Oct 6, 2006 | 03:05 PM
STL94LT1's Avatar
STL94LT1
Is the car stock or modified?
Old Oct 6, 2006 | 04:14 PM
ghallam's Avatar
ghallam
It has a Borla cat back exhaust, and K&N air filter. All the rest is stock.
Old Oct 6, 2006 | 05:23 PM
Daddy J's Avatar
Daddy J
Make sure the engine is hot (drive 20 miles) before you take it in for testing. I found that there was a big difference in readings between hot and if I just took it out of the garage and drove a couple of miles to the test place. 95 coupe/87k miles
Old Oct 6, 2006 | 05:44 PM
ghallam's Avatar
ghallam
I drove about 4 or 5 miles to the test station. Thanks for your advice. Also could the O2 sensor cause this problem?
Old Oct 7, 2006 | 10:00 PM
SunCr's Avatar
SunCr
I'm sure your engine was sufficiently warm for it to pass - specs require that it be so and there's little need to drive the bejesus out of it if it's working right - which - yours may not be. Most HC and CO failures are because the ECM is delivering too much fuel. The other cause is the CAT. Can you scan it and get some BLM's? Makes it lot easier, but presuming it's adding fuel it doesn't need, then you look for anything that's letting extra air blow past the O2(s). That would include vacuum and exhaust (header) leaks and/or a faulty air pump circuit. Otherwise, if the scan shows that fuel delivery is honkydory, probably time for a new CAT. If you can get some numbers and post them, it would help.
Old Oct 10, 2006 | 01:21 PM
miris32's Avatar
miris32
I have a 93 also, and failed emissions with similar numbers. While installing an oil cooler for my transmission I discovered that my air pump is seized up. Check yours to make sure it's running. I haven't been for a retest, and have not had any luck finding a rebuild kit for the pump, or a used one. The new baby is $200+ from what I have seen.
Old Oct 10, 2006 | 07:15 PM
SunCr's Avatar
SunCr
I don't know how a seized pump would keep it from passing - The LT motors only use it at start up to help light off the O2(s) and CAT - It doesn't play a role once warmed up. Of course if you stay open loop, it isn't going to pass, but heated O2's should eventually get there. Usually if the pump circuit is the cause, it's because one of the header checkvalves is broken or the pump is continuing to run after it's up to temp. Either situation will cause the O2 to sense a lean condition and the ECM dumps in too much fuel.
Old Oct 11, 2006 | 05:06 PM
ghallam's Avatar
ghallam
I now have a code 64 stored, which is right bank O2 sensor lean. I am going to replace the O2 sensor and see if this solves the problem.
Old Oct 12, 2006 | 09:26 PM
SunCr's Avatar
SunCr
Maybe - maybe not - if it doesn't, and the wiring is good (an open in the signal wire will generate the code) pull the check valve on the right header and make sure that air only goes through it in the direction of the header.
To failed emission
