Weighed my C4. Can this be right?
Old Oct 7, 2006 | 02:20 PM
ZBRA's Avatar
ZBRA
Default Weighed my C4. Can this be right?
Weighed using a set of Intercomp racing scales. They were calibrated last year.
1994 6-speed Coupe, glass top, both power sport seats, ~1/8th tank of gas, OEM wheels (8.5 frt & 9.5 rear), 100% stock car.
LF 903
RF 845
Front total 1748
LR 756
RR 744
Rear total 1500
Car total 3248
Old Oct 7, 2006 | 02:22 PM
vader86's Avatar
vader86
sounds right to me for a coupe
Old Oct 7, 2006 | 02:23 PM
Random84's Avatar
Random84
Generally, you're in the ballpark. Esp. with a near-empty tank and a few pieces missing...
Old Oct 7, 2006 | 02:25 PM
106mm's Avatar
106mm
Sounds close to me.
Old Oct 7, 2006 | 02:29 PM
pablocruise's Avatar
pablocruise
Sounds 'bout right to me too.
That corner weighting really reveals where the weight is!
I'm planning on doing that to mine eventually. Would like to have a better F/R balance ratio.
Are you planning on any re-distribution of weight somehow?
Old Oct 7, 2006 | 02:32 PM
toptechx6's Avatar
toptechx6
My black book lists the weight of a 94 coupe at 3309 so you are very close.
Old Oct 7, 2006 | 03:52 PM
VenkmanP's Avatar
VenkmanP
Originally Posted by ZBRA
I figure the radiator/cond/fan/shroud assembly weighs about 80 lbs maybe 100 with coolant.
The coolant alone would be ~40 lb.
This brings the total to 3290. Seems a bit low to me. Can that possibly be correct?
That's pretty close to the published curb weight. Why does it seem low?
Just noticed this:
~1/8th tank of gas
Curb weight is with full tank of gas, so actually it looks like your car is a porker...
Old Oct 7, 2006 | 03:54 PM
VenkmanP's Avatar
VenkmanP
LF 874
RF 816
This is the one slightly surprising thing. That's a big difference in weight. You got a double-size battery in there?
Old Oct 7, 2006 | 03:57 PM
Grease Monkey's Avatar
Grease Monkey
From: Hampton, VA Yea, i'm a redneck... but you love it
Cruise-In 8-9 Veteran
aka/Trunk Monkey/Banned For Life/Corvette For Life
its bout right
Old Oct 7, 2006 | 04:33 PM
NitrousSam's Avatar
NitrousSam
Default Weight
Sounds extremely close. I am guessing you took off close to 80 lbs in parts plus you have very little fuel in the car.
Old Oct 7, 2006 | 04:48 PM
Cold_B's Avatar
Cold_B
I agree. My 96 LT4 with subs, a full tank, headers, exhaust, lightweight flywheel, and chrome GS rims and a bunch of random junk in the car came in at 3360.
Old Oct 7, 2006 | 05:36 PM
ZBRA's Avatar
ZBRA
I thought they were closer to 3400-3500. Didn't realize 3250-3300 would be in the norm.
I'll weigh the radiator/shroud/fan assembly and add that to the front weight to get a more accurate weight.
Today I have removed all of the A/C stuff, the complete exhaust, and a few other odds and ends. Bet it's a good bit lighter now.
Old Oct 7, 2006 | 07:48 PM
Hotred94's Avatar
Hotred94
I weighted mine this summer on some scales accurate to within 10 lbs. I've done some lightening and had about 1/8th of a tank. Weight was 3140.
Old Oct 7, 2006 | 08:33 PM
bent's Avatar
bent
my old 88 with drag-lites & E.T. streets, no spare, 1/4 tank= 3,080
3,280 with driver!!....
Old Oct 7, 2006 | 09:25 PM
C4DC's Avatar
C4DC
St. Jude Donor '06
Battery, A/C compressor, and alt are all on the drivers side. Makes me wonder why the engineers didn't reverse it to help balance out the driver.
Old Oct 7, 2006 | 11:25 PM
Mr6spd's Avatar
Mr6spd
Believe it or not , I just weighed a radiator, shroud, condensor, fans, and calculated water weight (for radiator and hoses only - 8lbs of water) last week ... Total: 46 lbs.
Old Oct 7, 2006 | 11:34 PM
Mr6spd's Avatar
Mr6spd
Let us know the total on the AC system weight.
To Weighed my C4. Can this be right?
Old Oct 8, 2006 | 01:44 AM
Gar's Avatar
Gar
Weighed the mufflers after I removed them. Thirty pounds each!
Old Oct 8, 2006 | 03:42 AM
red L98's Avatar
red L98
thats what i did to my car , put everything i can on the pass side to make up for the drivers few extra LBs
Old Oct 8, 2006 | 09:49 AM
black85's Avatar
black85
It looks like relocating the battery would be fairly effective to help balance the front left and the back right.
I just installed an Optima redtop in my passenger side storage compartment. I think it weight about 35 lbs. I did add a few pounds of 2 gauge wire though. It was really easy. Just one wire to the starter and a ground to chassis. I can switch the battery back in just a few minutes b/c I got the Optima w/ side mounts and top posts. I just left the factory cable where they were with some tape on the positive.
F.Y.I.--My car weighs 3330 with me in it.
Dave
