"slight hesitation" before acceleration "slight"
my 86 hesitated big time. I had a lot of vacuum leaks and the idle air control valve couldn't overcome all the extra leaked air.
after plugging the leaks, it ran a lot better.
check the cruise control checkvalve at the left side of the distributor,
check all the vacuum hoses,
check the fuel purge hoses under the left headlight,
check the cruise control hoses by the battery,
check the heater and airconditioning plastic tubing that goes through
the firewall with the computer wiring,
Check the vacuum lines that control the heater valve
check check check
not a good thing to do, but go buy a little syringe at the local drug store, put a piece of hose about 6 inches long on the end, and drip about 3 drops at the base of the fuel injectors. If the engine idle changes, the injector o-rings are leaking. be careful, and remember gas is explosive, causes burns, and is a skin irritant.
it can burn you on a hot engine, and don't do this in your garage if you have a water heater in there.
check check check
Just my $0.05. Good luck.
