big problems with clutch i think?
Old Oct 8, 2006 | 05:48 PM
all show and more go's Avatar
Default big problems with clutch i think?
ok 2 days ago i got my car back from the shop and drove it a bit running fine except for the gears i had to push them in to get it into gears, so yesterday me and my pops decided to bleed the system and when i turned on the car it wont get into any gear but reverse and reverse has a real ruff grind.So today i decided to put it into gear and the start it but when i do the engine cuts out after a few second.Im going nuts i just put a bunch of money in it and i cant even drive it.I NEED EVERYONES HELP PLEASE
Old Oct 8, 2006 | 07:36 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default clutch
what job did the shop do? what year car?
sounds like the cluch master cylinder is kaput, internally bypassing,
get a kit, and rebuild it. or they messed with the geometry of the linkage under the dash when they put stuff back
Old Oct 9, 2006 | 09:43 AM
neat's Avatar
neat
What year is your car? Is a 4+3 or a ZF6?
I think when you bled it you introduced a bunch of air into the system, and now the clutch is not disengaging at all. If you have the car off and in gear, push the clutch in and see if the car will roll around. If you can't push the car unless it's out of gear, the clutch is not letting go.
Give us some more information, and we'll see if we can help you out some more.
Might want to check out the C4 FAQ at the top of the page too, lots of good stuff there.
Old Oct 9, 2006 | 12:42 PM
its an 86 with 4+3, thanx
To big problems with clutch i think?
