EGR solenoid
Old Oct 8, 2006 | 08:25 PM
mikey whipreck's Avatar
mikey whipreck
Default EGR solenoid
1985 L98
My EGR solenoid is bad.
I'm looking for recommendations on where to get a replacement. I wasn't able to find it in any of the catalogs, so I searched online at the parts stores (autozone/napa/advanced auto), this is what I found:
Wells $15.99
G.P. Sorensen $43.99
Delco???
Where'd you guys buy yours? What's the delco part number? I'll probably end up getting the Sorensen part, but If the Delco is close in price I'll get that.
Old Oct 8, 2006 | 09:03 PM
LS6 Motor's Avatar
LS6 Motor
It isn't available from AC Delco, I already tried, it is discontinued. Try Ecklers, they occasionally have some NOS parts. If not, GP Sorensen parts aren't bad. I have a MAP sensor from them, EGR, etc., with no problems.
Old Oct 9, 2006 | 12:43 PM
GIJoe's Avatar
GIJoe
St. Jude Donor '08-'09
picked mine up at AutoZone for like $40? I forgot the price, but it was the price to pay since the old one completely seized up.
Old Oct 9, 2006 | 02:45 PM
CFI-EFI's Avatar
CFI-EFI
A C Delco part number 214-331. Go HERE for applications. You can get it from GM Parts Direct.
RACE ON!!!
Old Oct 9, 2006 | 04:11 PM
Lone Ranger's Avatar
Lone Ranger
Wells stuff is really the crap. Probably get one of the other brands...
Old Oct 10, 2006 | 09:41 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
I picked up an O.E.M. Delphi unit from these guys.
http://www.buyautoparts.com/gm-parts/
Free shipping over $50 and they shipped the same day, too.
Old Nov 9, 2006 | 02:03 PM
JAKE's Avatar
JAKE
RACE ON!!!
The ACDelco unit for 93-96 is part # 214-396 (GM#1997223); about $25.00 + shipping.
Jake
Old Nov 9, 2006 | 03:31 PM
Bob89c4's Avatar
Bob89c4
What ever you do DON"T BUY THE WELLS !!
Old Nov 9, 2006 | 03:32 PM
94ZR1's Avatar
94ZR1
St. Jude Donor '06
Avoid wells like the plague
Old Nov 10, 2006 | 08:43 AM
mikey whipreck
I forgot to close out this thread, sorry.
I ended up getting the Delco from the local napa. Part number 214-331 (thanks CFI-EFI) for about $38. It's an '85 specific part I believe.
My old solenoid was stuck open, it would not hold a vacuum. The new one does. Thanks all for the input.
Old Nov 11, 2006 | 08:28 PM
Nazgul1010's Avatar
Nazgul1010
If you don't mind me asking, what were the driveability issues that led you to your solenoid?
Old Nov 11, 2006 | 10:32 PM
JAKE's Avatar
JAKE
Not sure who you addressed this to but:
In my case there was NO drivability issue, other than the Service Engine Soon dash light. Car ran fine without a hitch.
It was only after I went to AutoZone and had them pull the code that I learned it was EGR related.
I FINALLY RECEIVED THE SERVICE MANUALS FOR THE 1996 VETTE, and I began by following the trouble shooting directions. When it came to the part of using a hand held vacuum pump to test the EGR. I hit a brick wall.
AutoZone, O'Reilly's nor Pep Boys carried the pump, so I was relagated to being a "parts changer" - which I hate with a passion.
I bought and changed the solenoid (cheapest and easiest to swap out), but still got the code after clearning it.
Yesterday I ordered a new EGR valve, $65.xx, which should be here in a few days.
Failing that as the cure, I'll be back, open for suggestions.
One final option is to have Bryan turn it off in the PCM.
Just my tale.
Jake
Old Nov 15, 2006 | 12:35 AM
JAKE's Avatar
JAKE
I put on the new EGR Valve this afternoon - super simple.
Solved my problem.
Jake
To EGR solenoid
